Color sensor V1 (rgb)
nxt1engineer
Post by nxt1engineer »
Hello i have two colorsensor V1 (3 leds) 64892
The not working on my bricks, V1.? Firmware 1.29 and 1.31
What can be the problem, are the sensor brokken?
Please help
nxt-pro
Re: Color sensor V1 (rgb)
Post by nxt-pro »
How have you got tested the sensors?
Have you got the LEGO-Firmware or the Enhanced firmware other any other firmware?
Do other sensors work on this NXT?
nxt1engineer
The brick work well,
i have import the color sensor block (V1 and V2) and insert in a simpel programm.
The sensor read values (if i hold it for a light source ) but the is no generarted ligh
Maybe you could post the code you used here, in a zip-file
There are a couple color sensors available, one from LEGO, and one from HiTechinic. They do NOT use the same software.
Sounds like you have the one from LEGO (with three lights). I don't think the software (block) is available for that sensor as a separate download. It should be included in the software you got with your NXT 2.0 kit where you got the sensor.
nxt1engineer
Ok its a lego sensor type 64892
I do not have the NXT2.0 vesion sofware, im working with Lego Mindstoms educatie V2.0 (2008-10-20-1215)
Maybe that is the problem ?
Is NXT V2.0 update available on internet ? Or a block for this sensor?
I would have thought the Education version 2.0 would include everything the standard version has, but just in case I'm wrong you can get a standard download here -
http://service.lego.com/en-us/HelpTopic ... ionID=2655
nxt1engineer
thanks for the link, a get it from the lego support site, and download the cd.
I like the 2.0 edu version, can i import some block or so, or is the a new edu. version?
I have test the sensors with the firmware 1.31 and the working.
