bluetooth headset connection
hii ppl
i am working on senior project and i am using a NXT brick.
i am trying to connect a bluetooth headset to the NXT but "line is busy" statement come up!
is there is a specific bluetooth headset used to NXT ?? or any one can help fixing this problem??
i appreciate your help
thanks alot
thanks alot
Re: bluetooth headset connection
I'm pretty sure you won't be able to do this. The NXT Bluetooth device does not support a profile that will allow connection to a headset...
Thanks a lot for your fast reply...
so, is there is away of sending data from the NXT to an iphone via bluetooth??
The NXT BT module only supports serial connections, but I think it should work with an iphone.
The iPhone does not accept generic serial connections. The only solutions I have seen connect to the pc over bt and then to the iPhone (over tcp?).mattallen37 wrote:The NXT BT module only supports serial connections, but I think it should work with an iphone.
okay, then is it possible to send data from the NXT to an android phone??
because i'm using the NXT along with the sensors for obstacles detection to help blind people, and i want to alert the person with sound if he is facing an obstacle, that why i wanted to use a headset. But since it is not possible to connect a headset with the NXT DO YOU HAVE ANY SUGGESTIONS???
i'm new to this field and i don't have any previous knowledge, i really appreciate you help:)
Thanks a lot:)
Thanks a lot:)
I think connecting to an android is possible, don't ask me how, I don't know.
But why not take the simple solution? Use the NXT speaker.
Yes, in fact, there is an Android app called MINDdroid that is made to remote control basic robots. And since the Android SDK is free, you can make your own apps too.thunderf31 wrote:okay, then is it possible to send data from the NXT to an android phone??
it will be annoying for the surrounding people!aswin0 wrote:I think connecting to an android is possible, don't ask me how, I don't know.
Thank u for you help..
At least they know they are standing in the way.thunderf31 wrote: it will be annoying for the surrounding people!
To be serious, you could start simple and build on from that.
