bluetooth headset connection
thunderf31
Post by thunderf31 »
hii ppl :)
i am working on senior project and i am using a NXT brick.
i am trying to connect a bluetooth headset to the NXT but "line is busy" statement come up!
is there is a specific bluetooth headset used to NXT ?? or any one can help fixing this problem??
i appreciate your help
thanks alot :)
Re: bluetooth headset connection
Post by gloomyandy »
I'm pretty sure you won't be able to do this. The NXT Bluetooth device does not support a profile that will allow connection to a headset...
thunderf31
Thanks a lot for your fast reply...
so, is there is away of sending data from the NXT to an iphone via bluetooth??
The NXT BT module only supports serial connections, but I think it should work with an iphone.
aswin0
Post by aswin0 »
mattallen37 wrote:The NXT BT module only supports serial connections, but I think it should work with an iphone.
The iPhone does not accept generic serial connections. The only solutions I have seen connect to the pc over bt and then to the iPhone (over tcp?).
thunderf31
okay, then is it possible to send data from the NXT to an android phone??
because i'm using the NXT along with the sensors for obstacles detection to help blind people, and i want to alert the person with sound if he is facing an obstacle, that why i wanted to use a headset. But since it is not possible to connect a headset with the NXT DO YOU HAVE ANY SUGGESTIONS???
i'm new to this field and i don't have any previous knowledge, i really appreciate you help:)
Thanks a lot:)
aswin0
Post by aswin0 »
I think connecting to an android is possible, don't ask me how, I don't know.
But why not take the simple solution? Use the NXT speaker.
thunderf31 wrote:okay, then is it possible to send data from the NXT to an android phone??
Yes, in fact, there is an Android app called MINDdroid that is made to remote control basic robots. And since the Android SDK is free, you can make your own apps too.
thunderf31
aswin0 wrote:I think connecting to an android is possible, don't ask me how, I don't know.
it will be annoying for the surrounding people!
Thank u for you help..
aswin0
Post by aswin0 »
thunderf31 wrote: it will be annoying for the surrounding people!
At least they know they are standing in the way.
To be serious, you could start simple and build on from that.
