Wanted: Firmware Hackers...
mrblp
Re: Wanted: Firmware Hackers...
Post by mrblp »
nxtboyiii wrote:On the registration page I don't know what to fill in for some of the fields. Can you tell me what to fill in exactly or post the IAR installer or program in a zip?
Come on! You registered yourself in this forum - so why are you not able to register at iar? You can fill in everything and set all those company / project related questions to "other". That's it.
schodet wrote:It works! ... The first commit split cCmdWrapDrawPicture in two parts, the second one is a really dirty hack to display .ric files in the "Sound files" menu ;-).
Great work :-) I will see what I can do because I have the ui for ric-files - but the function is missing ;-) So I will try to combine our codes tomorrow.
Just one thing - the change in the c_cmd.h-file is related to your split up function - not to the "dirty sound file"-hack.
Bye - marvin
lms_arm_no_datalog_obp_v1.29b..zip
stripped down firmware with ric in menu (but no view function)
(73.24 KiB) Downloaded 701 times
Bye Marvin
nxtboyiii
Post by nxtboyiii »
I have downloaded the workbench and sourcecode of firmware. How do I get started and compile it all?
mrblp
Post by mrblp »
nxtboyiii wrote:I have downloaded the workbench and sourcecode of firmware. How do I get started and compile it all?
Start the IAR Workbench and open project LMS_V02.eww in AT91SAM7S256\SAM7S256\Tools\
Have fun!
Bye - marvin
Bye Marvin
nxtboyiii
Post by nxtboyiii »
But how do I compile it and delete the NXT datalog, NXT Program, Try Me, and the startup screen?
By reading a buttload of source code, documentation and making a lot of mistakes.
There is no magic trick to knowing this stuff.
schodet
Post by schodet »
mrblp wrote:Great work :-) I will see what I can do because I have the ui for ric-files - but the function is missing ;-) So I will try to combine our codes tomorrow.
Actually, I was not sure where to place the declaration (it is in c_cmd_drawing.c yet), so I left it in the "dirty" commit.
nxtboyiii
Post by nxtboyiii »
How do I compile the firmware into an .rfw.
Can someone tell me how step by step, starting from opening the LMS_ARM workspace?
nxtboyiii
Post by nxtboyiii »
Can I edit John's Enhanced firmware and compile it?
I can't debug it because it says I am not connected to the J-Link via USB.
Can someone help?
I think that is referring to the JTAG connector on the NXT PCB. In order to debug, you need to solder on a header, and have it connected to the computer through an interface (not the same as using the USB port on the NXT).
nxtboyiii
Post by nxtboyiii »
But how do I actually compile it into an rfw?
