Grabbot
romakos
Grabbot
Post by romakos »
Hello. I need some help. I have problems with grabbot. Robot who will take and lift ball or basket(of lego-blocks). Can u sent me some images or give me interesting idea. For example: http://www.laurensvalk.com/includes/nxt ... /main1.jpg. But it is too difficult to build. Help me :)
romakos
Re: Grabbot
Post by romakos »
May be u have a building instruction of this NXT Robot. If u have pls give me url :)
Re: Grabbot
pepijndevos
Re: Grabbot
Post by pepijndevos »
Depending on what you want, this one might work: http://studl.es/2012/01/pincer-bot/
-- Pepijn
mcsummation
Re: Grabbot
Post by mcsummation »
Actually, the one he posted the photo of is the 2.0 version - http://www.laurensvalk.com/nxt-2_0-only/the-snatcher, which is in the book http://www.amazon.com/LEGO-MINDSTORMS-N ... 866&sr=8-1
It is quite complicated, although easy enough to build with his instructions.
Re: Grabbot
The snatcher is a fantastic robot. I used it as a base for my Pneumo-Snatcher :)
pepijndevos
Re: Grabbot
Interesting, how do you switch the pumps?
Is the secret inside the black box?
I have tried to make some sort of binary switch, to control an unlimited number of switches with one motor. But I have not succeeded at that so far.
-- Pepijn
Re: Grabbot
You mean switch the valves? He used the Servo Operated Pneumatic Valve Kit from mindsensors.
Re: Grabbot
mattallen37 wrote:You mean switch the valves? He used the Servo Operated Pneumatic Valve Kit from mindsensors.
He sure did! The accompanying article is here: [LINK]
pepijndevos
Re: Grabbot
Ohnoes! The valves are out of stock :( I wonder if you can connect a regulator to the servo controller. Insane amounts of brushless power!
-- Pepijn
