Hello Forum,
I'm close to crying. I'm eager to get my two NXTs communicating with each other through the RS-485 port. I'm trying to establish the communication with NXC. Yet unsuccessful. I'm using the latest version of the nbc compiler available for mac.
On my mac (running: 10.6.6) I get a few errors when compiling John Hansen's example: ex_RS485Receive.nxc (http://bricxcc.sourceforge.net/nbc/nxcd ... le.html#a0)
Here are the first three (it kinda goes on like this…):
#Error: Undefined Identifier RS485Enable File[…] ; line 8
# RS485Enable(
#Error: ";" expected File […] ; line 8
# RS485Enable()
#Error: Unmatched close parenthesis File […] ; line 8
# RS485Enable();
On my mom's mac (running: 10.5.8) I get this error:
#Error: Preprocessor macro function does not match instance (#asm{__UseRS485() })
Now why would the errors change when using the same compiler? And why won't the example code compile successfully? Please help me, I need to get this running real real real soon for my Science Fair Project! I will be your biggest fan if you can help me out. Do I need to include a file perhaps?
Thanks in advanced
NXC: RS-458
Re: NXC: RS-458
Has anybody else been able to compile this example?
Re: NXC: RS-458
That example compiled perfectly fine for me. I am running Win 7 64-bit, with BCC 3.3.8.10, and NBC 1.2.1.r4.
I don't think I have tried running the examples, but I have successfully used my own RS-485 programs.
Edit: I am running 1.31 EFW.
Re: NXC: RS-458
Could you share your code? Could you try compile the example? That would help me a lot.
Thanks though.
Thanks though.
Re: NXC: RS-458
Well, it is certainly not in a "share" type setup. I used these for debugging the lib I was writing. Here is the lib:
Master program:
Slave program:
I just ran a test, exactly as they are, and it worked fine. The master sends 10 numbers (random) to the slave, and the slave responds with 10 numbers (random). I really don't think I can explain it very well, as it was quite a while ago that I wrote them. I do know however, that the lib does not do any error checking (no CRC or checksum).
Hopefully you will be able to get something out of it.
My RS485 protocol data specs:
Sending byte array looks like this:
Senders address, Target address, Commands(flags), Data1, Data2, ..., Data n
Sending Ping looks like this:
Senders address, Target address, Ping Flag Value
Acknowledgement looks like this:
Senders address, Target address, Acknowledgement Flag Value
Returned values
-2 timeout
-1 something went wrong, probably not right address
0 not acknowledged
Command = success
#define Master485Address 0x00 //The address of this NXT
#define Slave1485Address 0x01 //Slave number 1's address
//Master to slave flags
#define PingValue 0x08 //Return an Acknowledgement
#define WriteValue 0x10 //Write registers
#define ReadBackValue 0x20 //Return Values
//Slave to master flags
#define Acknowledge 0x01 //Result returned from a ping or write-only command
void SendRS485ByteArray (byte SenderAddress, byte TargetAddress, byte Command, byte SendData[]){
byte SendCompleteData[];
byte SendCompleteDataLength=ArrayLen(SendData)+3;
ArrayInit(SendCompleteData, 0, SendCompleteDataLength);
SendCompleteData[0]=SenderAddress;
SendCompleteData[1]=TargetAddress;
SendCompleteData[2]=Command;
byte i=0;
repeat(ArrayLen(SendData)){
SendCompleteData[i+3]=SendData[i];
i++;
string StringSendData = FlattenVar(SendCompleteData); //Flatten it into a string
SendRS485String(StringSendData); //Send the string
until(HSOutputBufferOutPtr() == StrLen(StringSendData)+1); //Wait until the string has been sent
int MasterReadRS485ByteArray (byte My485Address, byte BytesToReceive, int TimeOut, byte & InArray[]){
bool TimedOut=false;
byte TimePassed=0; //Reset the timeout counter
byte cnt;
string InString;
byte RawInArray[];
byte RawInArraySize=BytesToReceive+3;
ArrayInit(RawInArray, 0, RawInArraySize);
until (HSInputBufferInPtr() >= (BytesToReceive+4) || TimedOut){ //Until whole string is received
Wait(1); //Wait 1 ms
if (TimeOut==0){ //If TimeOut equals 0, then don't time out.
TimedOut=false;
else{
TimePassed++; //increase the timer
if (TimePassed>=TimeOut){
TimedOut=true;
if (TimedOut){ //If the timeout took place
return -2;
else{ //If the timeout did not take place
cnt=HSInputBufferInPtr();
GetHSInputBuffer(0, cnt, InString); //Read the buffer
SetHSInputBufferInPtr(0);
UnflattenVar(InString, RawInArray); //Unflatten the string into an array
byte SendersAddress=RawInArray[0];
byte TargetsAddress=RawInArray[1];
byte Command =RawInArray[2];
if (TargetsAddress==My485Address) //If the RdataC[0] contains this NXT's address, read the rest
ArraySubset(InArray, RawInArray, 3, NA);
return Command;
return -1;
void MasterSendPing(byte My485Address, byte TargetAddress){
byte PingData[3];
ArrayBuild(PingData, My485Address, TargetAddress, PingValue); //Build the array to send
string StringPingData = FlattenVar(PingData); //Flatten it into a string
SendRS485String(StringPingData); //Send the string
until(HSOutputBufferOutPtr() == StrLen(StringPingData)+1); //Wait until the string has been sent
int MasterCheckAcknowledgement(byte My485Address, int TimeOut){
string InString;
byte RawInArray[];
ArrayInit(RawInArray, 0, 3);
until (HSInputBufferInPtr() == 4 || TimedOut){ //Until whole string is received
TimedOut=false;
else{
TimedOut=true;
return -2;
GetHSInputBuffer(0, 4, InString); //Read the buffer
if (TargetsAddress==My485Address) //If the TargetsAddress contains this NXT's address, read the rest
return Command;
return -1;
int MasterPing(byte My485Address, byte TargetAddress, int TimeOut){
MasterSendPing(My485Address, TargetAddress);
return MasterCheckAcknowledgement(My485Address, TimeOut);
void SlaveAcknowledge(byte My485Address, byte TargetAddress){
byte AcknowledgeData[3];
ArrayBuild(AcknowledgeData, My485Address, TargetAddress, Acknowledge); //Build the array to send
string StringAcknowledgeData = FlattenVar(AcknowledgeData); //Flatten it into a string
SendRS485String(StringAcknowledgeData); //Send the string
until(HSOutputBufferOutPtr() == StrLen(StringAcknowledgeData)+1); //Wait until the string has been sent
int SlaveReadAndRespondRS485ByteArray (byte My485Address, byte BytesToReceive, int TimeOut, byte SendValues[], byte & InArray[]){
byte GoOn=0;
int TimePassed=0; //Reset the timeout counter
byte cnt;
string InString;
byte RawInArray[];
until (HSInputBufferInPtr() >= (BytesToReceive+4) || GoOn!=0){ //Until whole string is received
Wait(1);
if(HSInputBufferInPtr()==4){ //If only a ping
Wait(3);
if(HSInputBufferInPtr()==4){ //Confirm only a ping
GoOn=1;
if (TimeOut!=0){ //If TimeOut equals 0, then don't time out.
GoOn=2;
if (GoOn==2){ //If TimedOut
return -2; // Return -2
else{ //If it didn't time out
if (GoOn==0){
if (ReadBackValue==(Command&ReadBackValue)){
SendRS485ByteArray (My485Address, SendersAddress, Command, SendValues);
if (WriteValue==(Command&WriteValue)){
return Command;
if (GoOn==1){
if (PingValue==(Command&PingValue)){
SlaveAcknowledge(My485Address, SendersAddress);
return Command;
return -1;
}Code: Select all
Returned values
-2 timeout
0 not acknowledged
Command = success
#include "MyRS485 lib.nxc" //Note, the main library
#define My485Address 0x00 //The address of this NXT
#define Master485Address 0x00 //The address of the master
#define BytesToReceive 10
#define TimeOut 15
byte Sdata[]; //Array to send data
byte Rdata[BytesToReceive];
byte Svar0,Svar1,Svar2,Svar3,Svar4,Svar5,Svar6,Svar7,Svar8,Svar9;
int result;
task display() //Display the results
while(true)
NumOut(0, LCD_LINE1,Rdata[0]);
NumOut(0, LCD_LINE2,Rdata[1]);
NumOut(0, LCD_LINE3,Rdata[2]);
NumOut(0, LCD_LINE4,Rdata[3]);
NumOut(0, LCD_LINE5,Rdata[4]);
NumOut(50, LCD_LINE1,Rdata[5]);
NumOut(50, LCD_LINE2,Rdata[6]);
NumOut(50, LCD_LINE3,Rdata[7]);
NumOut(50, LCD_LINE4,Rdata[8]);
NumOut(50, LCD_LINE5,Rdata[9]);
NumOut(0, LCD_LINE8,result);
Wait(50);
task RS()
while (true)
Svar0=Random();
Svar1=Random();
Svar2=Random();
Svar3=Random();
Svar4=Random();
Svar5=Random();
Svar6=Random();
Svar7=Random();
Svar8=Random();
Svar9=Random();
ArrayBuild(Sdata, Svar0,Svar1,Svar2,Svar3,Svar4,Svar5,Svar6,Svar7,Svar8,Svar9);
SendRS485ByteArray (My485Address, Slave1485Address, (WriteValue|ReadBackValue), Sdata);
result=MasterReadRS485ByteArray (My485Address, BytesToReceive, TimeOut, Rdata);
//result=MasterPing(My485Address, Slave1485Address, TimeOut);
if (result==-1){
PlayToneEx(500,100,3,0);
if (result==-2){
PlayToneEx(1000,10,1,0);
Wait(500);
SetSensorType(IN_4, SENSOR_TYPE_HIGHSPEED); //Set up for RS485
SetHSState(HS_INITIALISE); // ''
SetHSFlags(HS_UPDATE); // ''
SetHSSpeed(HS_BAUD_921600);
SetHSInputBufferOutPtr(0);
start display;
start RS;
}Code: Select all
Senders address, Target address, Commands/flags, Data1, Data2, ..., Data n
Returned values
-2 timeout
0 not acknowledged
Command = success
#define My485Address 0x01 //The address of this NXT
#define TimeOut 500
byte Sdata[];
int result;
task display()
while(true)
Wait(75);
task RS()
while (true)
Svar0=Random();
Svar1=Random();
Svar2=Random();
Svar3=Random();
Svar4=Random();
Svar5=Random();
Svar6=Random();
Svar7=Random();
Svar8=Random();
Svar9=Random();
result=SlaveReadAndRespondRS485ByteArray (My485Address, BytesToReceive, TimeOut, Sdata, Rdata);
if (result==-1){
if (result==-2){
start display;
start RS;
}Hopefully you will be able to get something out of it.
Re: NXC: RS-458
These kind of errors suggest that you are not telling the compiler to target the enhanced NBC/NXC firmware, which these API functions require. Make sure that you pass -EF on the command line. Also make sure that you have the latest enhanced NBC/NXC firmware on your brick. I am fairly sure that adding -EF to your command line will fix the problem. Are you using nxtcc or the nbc command line compiler? If you are using nxtcc then I think you can set the compiler command line options via a preferences dialog - but I can't recall for sure what I have implemented in that tool at this point.webstorms wrote:Hello Forum,
# RS485Enable(
# RS485Enable()
# RS485Enable();
Re: NXC: RS-458
Thank you so much John! It compiles.
and thanks for the source code matt.
