Can you show me this program from NXT-G to RobotC ?
http://www.laurensvalk.com/images/downl ... 527&ex=rbt
thank you!
thank you!
Re: Can you show me this program from NXT-G to RobotC ?
You want that NXT-G program converted into ROBOTC?
Here is now I would go about doing it:
- - Determine the logic used.
- Create a loop and if statements to represent the loop and switches in the NXT-G program.
- Build ROBOTC chunks of code to represent the NXT-G blocks.
- Test to confirm it is working.
- Optimize the program by cutting out unnecessary lines of code.
I'm not gonna convert all the blocks into text code, but here is the logic (in NXC, not ROBOTC):That should be the same logic layout, you just need to build it in ROBOTC.
task main(){
SetSensorLight(S4);
SetSensorType(S4, SENSOR_TYPE_LIGHT_ACTIVE);
while(true){
Wait(300);
if(SENSOR_4<34){
else{
if(SENSOR_4>48){
else{
}Matt
oh I saw the source code but I cant control the motors with the light sensor... ;o/ Im new in this LEGO "World" and I must be done whit this project after 2 days... ;o/ I beg you to show me the whole source code... this is very important
thanks!
thanks!
I told you that was only the logic (and it's only the main structure for that matter), and in NXC (not ROBOTC). What I showed you is not source-code for the NXT-G program; it's my own hand-coded NXC program that makes up the logic used in the NXT-G program.
Why such a time-frame?
Like I said before, I don't program in ROBOTC. I can't magically convert an NXT-G program into ROBOTC, or any other language.
Why do you need the program in ROBOTC? What is the program for? Do you know that the NXT-G program works fine the way it is?
this is simple color sorter
here is the project:
http://www.laurensvalk.com/nxt-1_0-only ... orter-8527
it must be on RobotC because my professor want this ;o/
Does it need to be ROBOTC? Can it be NXC? Do you need a literal interpretation of it? Is a functionally equivalent version fine? Does it need to make sounds?
If this is for a school project, shouldn't you do the work?
without sounds... but okay write this program on NXC and I will try to make changes to work in RobotC
Well, I can try to make a working program in NXC. However, if you can't even begin to convert this yourself, I don't know how you will convert the NXC program into ROBOTC.
Can you please answer the other questions from my last post?
Well, here is an untested NXC program that I came up with.
bool PosRegComplete(byte port, int tolerance, long position){
if (MotorTachoCount (port)>=(position-tolerance)&&MotorTachoCount (port)<=(position+tolerance))
void Push(){
PosRegSetAngle (OUT_B, -85);
until(PosRegComplete(OUT_B, 5, -85));
PosRegSetAngle (OUT_B, 0);
until(PosRegComplete(OUT_B, 5, 0));
task main(){
PosRegEnable (OUT_A);
PosRegSetMax (OUT_A, 0, 0);
PosRegEnable (OUT_B);
PosRegSetMax (OUT_B, 0, 0);
SetSensorLight(S4);
while(true){
Wait(300);
if(SENSOR_4<34){ //Black
PosRegSetAngle (OUT_A, 50);
until(PosRegComplete(OUT_A, 5, 50));
Push();
else{
if(SENSOR_4>48){ //White
PosRegSetAngle (OUT_A, -50);
until(PosRegComplete(OUT_A, 5, -50));
Push();
else{ //Gray
PosRegSetAngle (OUT_A, 0);
until(PosRegComplete(OUT_A, 5, 0));
Push();
}Matt
