NXT 1.0 Segway Bot Problems
amigosdetamps
Post by amigosdetamps »
Hi, I have a problem I want to implement a segway lego nxt 1.0, but with the accelerometer sensor HiTechnic GYROSCOPE WITH NO NOT BECAUSE I HAVE WITH THE ANGLES AND SPEED CALCULATION ACCELEROMETER AS BUT NOT IMPLEMENTED TO FALL, BUT IS NOT DO I NEED A LITTLE HELP, I'M ONLY Mindful of the Y axis value
Re: NXT 1.0 Segway Bot Problems
I am not sure what you mean? You simply cannot make a segway with an accelerometer alone, you must have at least a gyroscope.
Oh and don't use caps, it's considered shouting. I would suggest you remove your CAPS lock key from your keyboard.
jojoguy14
Post by jojoguy14 »
mightor wrote: Oh and don't use caps, it's considered shouting. I would suggest you remove your CAPS lock key from your keyboard.
I wish I could do that. I've actually seen a program that just ignores it completely. Pretty nifty :-)
Known as jojoguy10
bungeshea
Post by bungeshea »
I'm not really quite sure what you mean, but David Parker invented a StegWay using just the NXT 1.0 set. It uses the light sensor to balance: http://nxtprograms.com/segway/
Also, Philo has made a similar project: http://philohome.com/nxtway/nxtway.htm
A couple links that may be useful...
http://www.teamhassenplug.org/NXT/NXTSensors.html
http://www.teamhassenplug.org/robots/legway/
Guess I need up update the links on the second page.
