[NXC] ArrayInit for 2D arrays
nxtboyiii
Post by nxtboyiii »
is there a way to reset the size of each dimension in an array?
Like this:
int map[10][20];
//Now I want to set the 1st dimension to 30, and the second dimension to 45
Re: [NXC] ArrayInit for 2D arrays
no, you can't resize a static variable during runtime, that's only possible with dynamic memory allocation like
malloc()
but you will need to have pointers for that...
(I wish NXC had it)
nxtboyiii
Post by nxtboyiii »
But it is possible to resize a 1D variable!!!
:shock: ?
show me an example, please...
You can resize any array in NXC using ArrayInit.
  int foo[10]; // foo has 10 ints in it.
  ArrayInit(foo, 0, 20); // foo now has 20 ints (all zero)
  int bar[10][20];  // bar is a 10 element array where each element is an array containing 20 ints.
  int tmp[]; // you need temporary arrays with N-1 dimensions (down to 1) to initialize an N-dimensional array
  ArrayInit(tmp, 0, 30); // first initialize the temporary array
  ArrayInit(bar, tmp, 15); // bar is now a 15 element array where each element is an array containing 30 ints (all zero).
amazing... :o
will the memory from upsizing be set free when you're downsizing it after using the bigger size for a while?
Or will the bigger size now be allocated in future?
so can you switch memory back and forth?
  int bar[10]; // bar the same
  ArrayInit(foo, 0, 32000); // foo now has 32000 ints (all zero)
  // not enough memory also for upsizing also bar[32000] at the same moment
  // so now first downsize foo:
  ArrayInit(foo, 0, 10);
  // what happens with the rest of 31990 int mem space?
  // can it now be used for bar?
  ArrayInit(bar, 0, 32000);
  ArrayInit(bar , 0, 10); // and resize back?
doc-helmut wrote:will the memory from upsizing be set free when you're downsizing it after using the bigger size for a while?
I did some tests a long, long time ago in a galaxy far, far away, and I believe the results showed that the memory is put back into the pool. (Otherwise, my program would have crashed due to multiple reallocations... I think.)
Whenever you realloc()ate using ArrayInit(), the memory that the original array "points" to gets free()d, and new memory is malloc()ated.
I wrote a macro for ArrayInit of 2D arrays and made some memory tests,
and the following is fine up to a 122x122 array of int (seems to be close to the variable space limit):
#define ArrayInit2D(bar, tmp, x, y) { \
  ArrayInit(tmp, 0, y); \
  ArrayInit(bar, tmp, x);  \
task main(){
  int ibar[][], itmp[];
  float fbar[][], ftmp[];
  int i, j, imax, jmax;
  jmax=imax=122;
  ArrayInit2D(ibar, itmp, imax, jmax);
  for (i=0; i< imax; ++i)  {
    for (j=0; j< jmax; ++j)   {
      ibar[i][j]=(i+1)*(j+1);
      TextOut(0,48, "                ");
      NumOut(0,48,ibar[i][j]);
  while (true) { }
this is fine for 2 arrays, each 60x60:
task main(){
  jmax=imax=60;
      TextOut(0,48, "                ");
  ArrayInit2D(fbar, ftmp, imax, jmax);
      fbar[i][j]=(i+1)*(j+1);
      TextOut(0,32, "                ");
      NumOut(0,32,fbar[i][j]);
  while (true) {}
this is fine for 1 array 122x122, the other 10x10:
task main(){
  jmax=imax=122;
      TextOut(0,48, "                ");
  ArrayInit2D(fbar, ftmp, 10, 10);
  for (i=0; i< 10; ++i)  {
    for (j=0; j< 10; ++j)   {
      TextOut(0,32, "                ");
  while (true) {}
