It's alliiiive! (armdebug for NXT Beta 1)
tcwan
Post by tcwan »
After much staring at assembly dumps and lots of help from various Mindboards folks, armdebug for NXT Beta 1 is finally working.
http://git.ni.fr.eu.org/?p=tcwan/nxt-fi ... ;a=summary
armdebug is an embedded ARM instruction level GDB debugger for the NXT, which operates using just a USB connection between the NXT and the Host (GDB debugger client). The host is supposed to be cross-platform (Mac, Windows, Linux), using nxt-python to provide the cross-platform support.
For Mac OSX (and probably Windows, I have not tested it on Windows yet), Fantom is the most reliable interface to NXT. Technically the armdebug Host should also work well on Linux, but it has only been tested in a Fedora 14 VM, where I found libusb to have less than satisfactory reliability and performance.
armdebug for NXT is dual licensed, either GPLv2 or LEGO Open Source Licence (to ease integration with other NXT firmware projects which may be interested).
There are several parts to this puzzle:
Currently armdebug for NXT is mostly useful for examining memory contents for the NXT firmware, since code executes directly from Flash and cannot be modified on the fly to support Single Stepping and Dynamically specified Breakpoints (manually specified breakpoints are ok, and one such breakpoint is embedded in my version of the firmware to trigger the Debugger). A more intelligent memory contents viewer can be built on top of the GDB interface but it is beyond the scope of my needs.
(I'll be focusing on NxOS support after this, which will support Single Stepping and Dynamically specified Breakpoints for RAM-resident programs).
A log of my GDB session is found below. I just picked some random routine name and variables from the NXT Firmware code for illustration.
$ arm-none-eabi-gdb nxt_firmware.elf
GNU gdb (GDB) 7.1
Copyright (C) 2010 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-apple-darwin10.4.0 --target=arm-none-eabi".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /Users/tcmac/gitrepo/nxt-firmware-tcwan/AT91SAM7S256/SAM7S256/gcc/nxt_firmware.elf...done.
(gdb) target remote localhost:2828
Remote debugging using localhost:2828
0x001001ee in cCommHandleDebug ()
(gdb) info reg
r0             0x0	0
r1             0x201e02	2104834
r2             0x0	0
r3             0x37	55
r4             0x20fefc	2162428
r5             0x20add9	2141657
r6             0x20ae1d	2141725
r7             0x12	18
r8             0x0	0
r9             0x0	0
r10            0x0	0
r11            0x40000	262144
r12            0xfffb0054	4294639700
sp             0x20febc	0x20febc
lr             0x1001e7	1049063
pc             0x1001ee	0x1001ee <cCommHandleDebug+14>
fps            0x0	0
cpsr           0x80000033	2147483699
(gdb) x /4h &BatteryLimits
0x125034 <BatteryLimits>:	6100	6500	7000	7500
(gdb) disass cUiGetString
Dump of assembler code for function cUiGetString:
   0x0010e524 <+0>:	push	{lr}
   0x0010e526 <+2>:	adds	r3, r0, #0
   0x0010e528 <+4>:	movs	r0, #0
   0x0010e52a <+6>:	cmp	r3, #0
   0x0010e52c <+8>:	beq.n	0x10e546 <cUiGetString+34>
   0x0010e52e <+10>:	cmp	r3, #61	; 0x3d
   0x0010e530 <+12>:	bhi.n	0x10e546 <cUiGetString+34>
   0x0010e532 <+14>:	subs	r3, #1
   0x0010e534 <+16>:	lsls	r3, r3, #16
   0x0010e536 <+18>:	lsrs	r3, r3, #16
   0x0010e538 <+20>:	lsls	r0, r3, #4
   0x0010e53a <+22>:	adds	r0, r0, r3
   0x0010e53c <+24>:	lsls	r0, r0, #16
   0x0010e53e <+26>:	lsrs	r0, r0, #16
   0x0010e540 <+28>:	ldr	r3, [pc, #8]	; (0x10e54c <cUiGetString+40>)
   0x0010e542 <+30>:	adds	r0, #8
   0x0010e544 <+32>:	adds	r0, r3, r0
   0x0010e546 <+34>:	pop	{r1}
   0x0010e548 <+36>:	bx	r1
   0x0010e54a <+38>:	nop			; (mov r8, r8)
   0x0010e54c <+40>:	andseq	r4, r2, r12, asr r5
End of assembler dump.
(gdb) x /16xb &VarsUi
0x20ba6c:	0x4e	0x58	0x54	0x00	0x00	0x00	0x00	0x00
0x20ba74:	0x00	0x01	0x78	0x48	0x01	0x00	0x00	0x00
EDIT: Updated URLs for pyfantom and nxt-python (SVN)
tcwan
Re: It's alliiiive! (armdebug for NXT Beta 1)
Post by tcwan »
2. nxt-python-fantom, aka nxt-python 2.1.0 with fantom support (currently a hack, available via the nxt-firmware-tcwan git repo: http://git.ni.fr.eu.org/?p=tcwan/nxt-fi ... om;hb=HEAD)
To follow up, nxt-python SVN http://code.google.com/p/nxt-python/source/checkout has now incorporated pyfantom support. The hacked version has been cleaned up from the armdebug subdirectory mentioned. So please get nxt-python SVN from the nxt-python subversion repository instead.
schodet
Post by schodet »
Good news :) I definitely have to try this now that I have some free time :)
schodet
Post by schodet »
I just tried it and it works really well. I used direct USB connection using libusb on a debian 6.0.
I was able to stop the firmware, look at some internal variables, and make it continue.
This will make future firmware work much easier!
