NXC code help!!!!!
nxtboyiii
NXC code help!!!!!
Post by nxtboyiii »
Hi
I am trying to figure out how to make a platformer game for nxt with nxc using tiles without the character moving tile by tile.
The Knight game I made moves smoothly tile by tile, so if you press the left button your character moves left 1 tile. I want to make it so the character moves left 1 pixel, not 16(The tile size).
Re: NXC code help!!!!!
Shouldn't this be in one a thread in NXT Software?!!!!!
nxtboyiii
Post by nxtboyiii »
Yeah, I guess(I'm afraid Mightor will take it off).
nxtboyiii
Post by nxtboyiii »
Anyone interested?
I really need help.
btw, heres the code I have now which moves tile by tile:
https://sites.google.com/site/nxtzips/posts
You can draw an RIC sprite at any X,Y position. If you know how to draw it at positions that are multiples of 16 then you know how to do it at positions that are multiples of 1. Just don't increment your position by 16. If you are using a complex RIC to draw the entire screen in one GraphicOutEx call then you may need two instead - one to draw the background and another (or multiple calls) to draw the character(s) on top of the background.
It is best to post simple code that is close to what you want and ask for help to make it do more closely what you want. I don't have time to plow through a thousand line program so KISS.
nxtboyiii
Post by nxtboyiii »
here is the basic code:
note- it does not compile
if you want the working version, download it from the website I mentioned earlier
short lvl;
bool done,s;
int xp,yp,c,d,xvg,oxy,money;
int cou[EMAX];
char sc[EMAX];
int iac[EMAX];
int EMYCT;
int rrx,rry;
string gstr="";
char recover;
char tostr[1];
int xguy,yguy,width,height,pm,xg,yg,yl,xn,yn,life,jumpcount,fallh;
int var[2];
int varg[1];
int emx[EMAX];
int emy[EMAX];
int epm[EMAX];
bool elive[EMAX];
int vare[1];
brk map[500];
task engine()
 int punchadd;
 while(1)
  GraphicOutEx(xg,yl,"guy.ric",varg);
  if(ButtonPressed(BTNCENTER,0) && SENSOR_1)
   until(!SENSOR_1);
   rrx=0;
   rry=height;
   xvg=width;
   s=1;
   Wait(100);
   TextOut(70,LCD_LINE3,StrCat("$",NumToStr(money)));
   TextOut(70,LCD_LINE2,StrCat("HP:",NumToStr(life)));
    for(int xv=0; xv < ArrayLen(map); xv++)
  if(xv == xvg)
	 xvg+=width;
   rry--;
   rrx=0;
    if(map[xv].SLD == 1)
   PointOut(rrx,rry);
	  rrx++;
  until(SENSOR_1);
  until(!SENSOR_1);
     d=(xguy/16*-1)+width*(yguy/16*-1)+7;
   c=(xguy/16*-1)+width*(yguy/16*-1);
   xp=0;
   yp=48;
   s=0;
   until(done);
  repeat(2)
  if(ButtonPressed(BTNCENTER,0) && !SENSOR_1)//Jump/climb
   until(!ButtonPressed(BTNCENTER,0));
   if((map[pm-width].SLD == 0 || (OnTile(pm,32,16) && map[pm-width].SLD == 0)) && jumpcount < 2 && map[pm-width].alv == 0)
    jumpcount++;
    	  if(pv == rit)
	   pv=ritj;
	  else if(pv == lft)
		 pv=lftj;
    if(yl == 32)
	  yn=16;
    yguy+=16;
    repeat(4)
		 yn-=4;
     AfterMove(25);
     DrawEMY(0,-4);
     yn=0;
AfterMove(0);
DrawEMY();
     else if(yl != 32)
      repeat(4)
   		 RectOut(xg,yl,11,11,DRAW_OPT_CLEAR | DRAW_OPT_FILL_SHAPE);
    	 yl+=4;
       AfterMove(25);
      pm-=width;
    if(ButtonPressed(BTNRIGHT,0))
   pv=rit;
  if(map[pm+1].SLD == 0 && map[pm+1].alv == 0)
   PlayFileEx("step.rso",Volume(),0);
   if(width-(xguy/16*-1) > 7)
/*            for(int e=0; e < EMYCT; e++)
	 emx[e]-=16;
	 xn=16;
	 xguy-=16;
       repeat(4)
		xn-=4;
AfterMove(25);
DrawEMY(-4,0);
       xn=0;
AfterMove(0);
   repeat(4)
   xg+=4;
      AfterMove(25);
    pm++;
    if(ButtonPressed(BTNLEFT,0))
   pv=lft;
  if(map[pm-1].SLD == 0 && map[pm-1].alv == 0)
   if(xg == 16)
	 emx[e]+=16;
	xguy+=16;
	xn=-16;
       repeat(4)
		xn+=4;
AfterMove(25);
DrawEMY(4,0);
       xn=0;
		 AfterMove(0);
   else if(xg != 16)
   repeat(4)
   xg-=4;
AfterMove(25);
    pm--;
      if(map[pm+width].SLD == 0 && map[pm+width].alv == 0)//Fall down
   if((OnTile(pm+width,32,16) && ButtonPressed(BTNEXIT,0)) || !OnTile(pm+width,32,16))
    fallh++;
       	  if(pv == rit)
	   pv=ritj;
	  else if(pv == lft)
		 pv=lftj;
   if(height-yguy/16*-1 > 4)
	yguy-=16;
 yn=-16;
       repeat(4)
		yn+=4;
AfterMove(25);
RectOut(0,60,100,4,DRAW_OPT_CLEAR | DRAW_OPT_FILL_SHAPE);
DrawEMY(0,4);
       yn=0;
AfterMove(0);
   repeat(4)
   yl-=4;
   AfterMove(25);
    pm+=width;
 	  if(pv == ritj)
	   pv=rit;
	  else if(pv == lftj)
		 pv=lft;
//draw the map tile by tile
task displaymap()
     unsigned long t0;
     while(1)
      done=0;
      until(s == 0);
      xp=0;
      yp=48;
      until(c >= ((xguy/16*-1)+width*(yguy/16*-1))+width*4) //loops until the y axis of the row is below the screen
       until(c==d)
        if(s == 1)
             goto end;
        var[0]=map[c].X;
        var[1]=map[c].Y;
        GraphicOutEx(xn+xp,yn+yp,"gmtilesb.ric",var);//draw a tile at the x axis of xn+xp, y axis of yn+yp
        //yn and xn are variables to make moving from tile to tile smoothly possible
       	xp+=16; //make the x axis of the next tile drawn 16 pixels to the right
       	c++;
       //go to the next line
       yp-=16;
       xp=0;
       d+=width;
       c+=width-7;
      done=1;
      Wait(20);
      end:
That's too much code for me to sort through. I would try fiddling around with some of those 16s to start with.
What problems are you having so far?
nxtboyiii
Post by nxtboyiii »
The player currently moves 1 tile at a time, smoothly. I want it so it moves 1 pixel at a time, so if you press a direction it only moves 1 pixel total and not moving a tile.
~nxtboyiii: Didn't you program the game? You of all people should know how to do that.
