MoCo Pan unit for time lapse photography
pavementpilot
Post by pavementpilot »
This is a MoCo Pan mount for time lapse photography. In time lapse, you need to move slowly when panning, tiltling, or crawling. I have reduced the gearing for 112:1 motor to turntable.
I would like to get slower, and that may come on future builds. I was also trying to incorporate tilt, but my Nikon D3100 with battery grip and both batteries, and lens is too heavy. I may design it still and use my Blackberry 9700 or Nikon Coolpix L18 with it. I decided to use this still of control and motor mount to avoid having a trailing cable.
I havent started shooting with this rig yet, as I just finished building, blueprinting, and programming it.
The definition of insanity is doing a repeated task over and over again, but expecting a different outcome everytime
Re: MoCo Pan unit for time lapse photography
Cool design, I like it.
To add tilt, perhaps you should make a cradle for the camera with a TT on each side (at center of gravity). That way, weight shouldn't be a big issue.
pavementpilot
D3100 with 18-55 lens + battery grip + 2 batteries is just a hair over 1kg. That is alot of weight for lego to support.
It really depends on how you build it. doc222 has a huge biped that weighs (IIRC) over 4 kg. He used TT's for the joints, and they seem to do pretty well. Also, with a camera, you can find the center of gravity, so rotation power isn't a big issue, just support.
pavementpilot
What are TT's?
pavementpilot
Here is the lxf and rbt files for this build.
MoCoPan.zip
(492.96 KiB) Downloaded 875 times
TurnTables (the 56 tooth gear made from two parts).
pavementpilot
Turntables, I should have caught that one. My brain is mush right now. My wife dragged me out to a list of 5 garage sales.
I feel your pain.
themindstormman
Post by themindstormman »
hey cool your on nxtlog too.
Themindstormman3141
NXT FOR ALL
