NXT Grayscale Screen?
Does anyone know how to make the nxt screen look grayscale?
Like for a splash screen for a game?
Could someone make a sample program of greyscale?
Re: NXT Grayscale Screen?
hi, The NXT screen is black and white... no grayscale unless you flash a pixel on and off many times a second... But the refresh rate for the screen is 10hz (10 times a second so that probably wouldn't look so good) (It would flicker)
In NXC you can change the contrast of the whole screen, but not individual pixels
-Tim
-Tim
Theoretically, it would require 24Hz * for a "smooth" blend, and a higher frequency if you want different shades of gray with the same "smoothness".timpattinson wrote:hi, The NXT screen is black and white... no grayscale unless you flash a pixel on and off many times a second... But the refresh rate for the screen is 10hz (10 times a second so that probably wouldn't look so good) (It would flicker)
-Tim
* 24Hz == 2 * 12Hz. 12Hz is sort of your eyes' capture rate.
I already know that you can only choose black or white, but I need a program for it that still looks ok. Like an actual picrure of something that "looks" gray.
The TI-84 calculator has only black and white, yet many grayscale pictures have been made using a flickering method.
That's probably because the hardware supports such high flickering speeds.nxtboyiii wrote:The TI-84 calculator has only black and white, yet many grayscale pictures have been made using a flickering method.
Try this:
#define TIME_BEFORE_INCREASE 100
#define INCREASE_BY 1
for(unsigned long waitTime = 0; 1; waitTime += INCREASE_BY)
for(unsigned long timer = CurrentTick(); (timer + TIME_BEFORE_INCREASE) > CurrentTick(); )
RectOut(0, 0, 8, 8, DRAW_OPT_FILL_SHAPE);
}Commit to LEGO Mindstorms Robotics Stack Exchange:
The NXT's screen is limited by hardware to about a 10Hz refresh rate. So flicker all you want, you won't see anything but a horrible shearing effect. If this is what you're after then by all means
I was just wondering the other day, if it is possible to speed up the refresh rate (for those who want to have grayscale). I think Nicolas increased the motor control update rate from 10Hz to 100Hz, so I wonder if the screen could also be updated that often (or if it already is, when using his FW). Is it totally a hardware set speed? I wouldn't assume so, 10Hz max speed based on hardware seems incredibly slow, for almost anything that is just handling signals. I would assume it is a software limitation (Firmware), and that is why I wonder if it could be increased (or already has been, by Nicolas). Just an idea I had the other day.
It's the controller for the screen that's the limiting factor, not the firmware.
Ok, I just thought that maybe the ARM just only updates the ATMEGA48 I2C registers 10 times a second. Nicolas somehow got the motor control update speed up to, I think 100Hz, and isn't the ATMEGA what controls the motors? I just wondered if the screen update speed was the same issue, and could be increased by faster/more frequent I2C updates.
Edit: So, you are saying that it is the ATMEGA48 that has the limit of 10Hz, and I was curious to know if perhaps 10Hz was the speed that the ARM updated the ATMEGA.
No, the screen is not controlled by by the Atmega, it's connected to the ARM with SPI. Take a look below, this is from the schematics PDF from the HDK.
Hope that clarifies it.
