NXC: syntax for passing a struct to a function?
I try to pass a structure to a function but I don't succeed- what is the right NXC syntax? (edit: the code is an excerpt from an original C file)
void DBG () {
  return;
/* Complex Numbers. */
/* complex number */
struct C {
  float re,
          im;
/* multply real, complex */
#define C_MUL( f, z)                   \
  do {                                 \
    z.re *= f;  z.im *= f;             \
  }  while (FALSE)
/* complex product constructor */
#define C_PRO( z1, z2) {               \
   re: z1.re * z2.re - z1.im * z2.im,  \
   im: z1.re * z2.im + z1.im * z2.re   \
/* bit reverse permutation */
void BRP (unsigned char ldN,
          struct C  vec []) /* 2^ldN */   // <<========================== ERROR !
  unsigned int N;
  unsigned int l, n, r;
  unsigned char b;
  N  = 1 << ldN;
  for (l = 0;  N > l;  ++ l)
     n = l;
     r = 0;
     for (b = 0;  ldN > b;  ++ b) {
        r <<= 1;
        if (0 !=  1 & n ) { r |= 1; }
        n >>= 1;
     }  // b
     if (l < r) {
        struct C     const z = vec [l];
        vec [l] = vec [r];
        vec [r] = z;
     }  // right
  }  // k
  return;
}  // BRP
task main() {
# Error: Unexpected character encountered
File "c:\Temp\temp.nxc" ; line 30
# struct C v
# Error: Variable name expected
# struct C v
# Error: Unknown datatype
# struct C v
File "c:\Temp\temp.nxc" ; line 32
# unsigned int const N
# Error: ';' expected
# unsigned int const N =
Re: NXC: syntax for passing a struct to a function?
You should only use "struct" at the declaration, just use "C" at the other places. The syntax by using "struct" each time it is needed actually looks weird to me but looking it up it really is the way it is supposed to be done in C... Did they change it in C++, or have I just always used classes instead?
I'm actually not sure if it's C or C++ code -
I just picked up the code while searching for implementations of a DFT(FFT) and now I despair of the error messages trying to use that code for NXC... ;)
edit: got the complex calculations working now, thx! :)
    struct C {
      float re;
      float im;
    // complex scalar product
    inline void  C_MUL(float f, C z, C &rz) {
      rz.re = z.re * f;
      rz.im = z.im * f;
    // complex product
    inline void  C_PRO(C z1, C z2, C &rz)  {
       rz.re = z1.re * z2.re - z1.im * z2.im;
       rz.im = z1.re * z2.im + z1.im * z2.re;
ps
Now I finally understood what this actually should mean in the original code:
pass an ARRAY (!) of struct to the function!
          C  vec [] ) // a vector of complex numbers = an array of 2-dim structs!
bullestock
Post by bullestock »
spillerrec wrote:You should only use "struct" at the declaration, just use "C" at the other places. The syntax by using "struct" each time it is needed actually looks weird to me but looking it up it really is the way it is supposed to be done in C... Did they change it in C++, or have I just always used classes instead?
Yes, in Standard C a type defined with 'struct' must always be referred to as 'struct X'. This is why you often see code such as
typedef struct
} X;
- in that way you can just say 'X x;' instead of 'struct X x;'.
In C++, types defined with class and struct can be referred to with or without 'class' and 'struct'.
I have no idea as to how NXC handles this, though.
