NXC: compile error using FormatNum
I get a compile error using FormatNum:
int ibuf;
string s;
s=FormatNum("%d", ibuf)+";" ;
# Error: ';' expected
File "c:\Temp\temp.nxc" ; line 98
# s=FormatNum("%d", ibuf)+"
what's wrong?
Re: NXC: compile error using FormatNum
Are you using the enhanced firmware?
int ibuf;
string s;
Should that not be :-
int ibuf;
string s;
s=StrCat(FormatNum("%d", ibuf),";" );
Just getting used to this C-based stuff so apologise if this is not helpful.
as I just found out, this works:
s=FormatNum("%d", ibuf);
s= s +";" ;
but this not:
Using NumToStr instead of FormatNum is the same issue.
hergipotter
Post by hergipotter »
I don't think there's a "+"-Operator for strings in nxc, is it?
Did you try it as h-g-t suggested?
s= s +";" ;
Does this really work as expected?
yes, it does
NXC supports string concatenation using + in some limited cases. IIRC, that is only when you have a string variable and/or constant and the + sign.
string a, b, c, d;
a = "123";
b = "456";
c = "789";
d = a + b + c + "0-=";
This will compile and work correctly but the NXC compiler does not currently support using the + for string concatenation in any other situation.
thank you John for the clarification!
Users browsing this forum: Semrush [Bot] and 37 guests
