NXC: ... display print output problem
I just came upon this issue:
this code works:
for (int z=0;z<8;z++) {
  NumOut(0,56-(z*8), (z&4)?1:0);
but this not:
  TextOut(0,56-(z*8), (z&4)?"TRUE":"FALSE");
why not?
Re: NXC: ... display print output problem
I suspect it's because it expects a string/variable. Not a bracket.
The way that I implemented this function in the compiler makes it not work for ?: expressions. What happens if you try using ?': when passing a string into a user defined function? I think ?: may not be fully is not supported for string expressions.
