how much memory needs the "pure" Linux OS on the EV3 flash and (when running) in the RAM ?
how much memory (flash/RAM) needs the Lego VM plus accessory files additionally?
EV3: memory details about OS / FW
Re: EV3: memory details about OS / FW
Hi Doc,
those questions are not that simple to answer. The EV3 is way more complex than the NXT in this respect. You will probably get better answers if you can explain what it is you want to do, why you need the memory usage.
if it's more complicated than I thought it would be, then I'd probably simply try it out if the VM task once is killed.
For the flash I was curious how many different (large) programs probably could be stored,
and about the RAM I was curious how much would be free for code stack plus memory stack + heap.
Hi Doc,
trying it would probably be best! For RAM usage the problem is it depends what else you need to have running (WiFi etc.). The EV3 has 64Mb of memory I would be very surprised if there is less than 32Mb avilable for your program (so about 1000 times more than the NXT!). How much memory do you think you will need? If things get tight then I'm sure you have other options, you can probably reduce the number of background processes running and even enable swap on an SD card, but obviously that means using some sort of custom configuration. Sorry can't help with flash as all of my usage is with an SD card, if you use one of those then you can have Gb of storage...
thx for your reply, I will try then.
Most of the memory would be needed for my new neural backpropagation net, the size by which I may design it depends on learning speed...
On my flash based OS (which does not have RAM drives), I have the following amounts of free memory:
So right now I have about 40-41MB free. I don't know how much memory the LEGO VM will allow you to allocate in your program.
= Xander
root@EV3:~# free
total used free shared buffers
Mem: 60932 19812 41120 0 2116
Swap: 0 0 0
Total: 60932 19812 41120= Xander
Users browsing this forum: No registered users and 0 guests
