hey,
what is the max output current of the EV3 brick for each motor port for short-time and continuous load ?
(in order to drive more powerful 3rd party DC motors providing higher torque)
unfortunately it's not published in the ev3 brick specs http://education.lego.com/de-de/lego-ed ... gent-brick
EV3 brick: max motor port output current
Re: EV3 brick: max motor port output current
As far as I know it uses the same driver chip as PF V2 receiver, so we can expect a much higer current. But this same chip can also be configured with a lower current limitation, and there is probably a battery input limitation (NXT had a 1.8 A rated resettable fuse). We'll need the HDK - or some testing - to make sure!
