Batteries and Battery packs
philoo
Post by philoo »
All you ever wanted to know about batteries and battery boxes to power your Technic or MINDSTORMS creations - discharge curves, capacity, voltage under load, current limitations...!
The results of an extensive test campaign are summarized here.
Here's the kind of data you'll find:
Enjoy!
aswin0
Re: Batteries and Battery packs
Post by aswin0 »
Thanks! Very informative.
Have you, or anyone else, experience with the new NiZn batteries?
Post by gloomyandy »
Hi Aswin,
I've used them a few times the 1.6V output can be handy at times. However note that this is a nominal value and I've seen freshly charged cells giving considerably more than that. I've never been brave enough to install 6 of them in an NXT!
Not an expert so not sure if I am looking at this from the correct perspective.
You seem to be comparing one AA cell to the battery pack, but in fact there are 6 cells in the NXT.
Would a normal load of NiMH's not last longer than the LEGO battery?
as all curves start at >7 V, I suppose it's meant for a 6 cells set then.
For 1 single cell, the related curves were supposed to start somewhere at 1.2 V - 1.5 V.
OOPS! Missed that, thanks for pointing it out.
Users browsing this forum: Amazon [Bot] and 23 guests
