NXT PROBLEM
naneczek
NXT PROBLEM
Post by naneczek »
I have attached bricx's algorithms and I stopped at a certain point. How can I modify/add to this code sth that will display on a screen the process of the distance frequency changing with one hundred measurements per second frequency. Each measurement is represented by a point on a screen and each measurement is supposed to be saved in an array and after that it would go back to the measurement mode. I hope this description is clear. There should be a loop and so on. Can anyone do this?
Untitled66.nxc
nxc
(169 Bytes) Downloaded 10921 times
Re: NXT PROBLEM
you can post your code using the code tags!
task main() {
int x;
int i;
SetSensorLowspeed(IN_4);
x = SensorUS(IN_4);
for (i=0;i<100;i++) {
PointOut(i,i);
while (true){
Re: NXT PROBLEM
the last while() needs a ; but don't need an extra { }.
In the loop you will have to poll the sensor each time.
Sensor US gives you just 1 reading about every 20ms because it's an i2c sensor.
The NXT screen x axis is 100 pixels wide, the y axis is about 70 pixels high.
assuming your US reading is up to 255 then you'd take 1/4 of your USS readings to fit to your y axis.
sth like this should do what you expected:
task main() {
  int y;
  int i;
  for (i=0;i<100;++i) {
    y = SensorUS(IN_4);
    PointOut(i, y/4, DRAW_OPT_NORMAL);
    NumOut(0,56, y, DRAW_OPT_CLEAR_EOL);
    Wait(1);
  while (true);
Re: NXT PROBLEM
ps
as the TOP is more a software issue it's supposed to be better located to the "Mindstorms Software" subforum!
naneczek
Re: NXT PROBLEM
Post by naneczek »
Thank You. Will this algorithm work like an oscyloscope? Measuring the distance from the object?
Re: NXT PROBLEM
you will have to reset i to 0 within the loop if it exceeds 100, and then to clear the screen,
but then: yes, I think so.
just add the line
if (i>=100) {i=0; ClearScreen();}
edit
as the 1st one in your loop.
And for you as a beginner just 1 extra hint:
for the start, ever use ++i or i+=1 instead of i++ unless you once will know exactly the difference.
(i++ may have unexpected side effects in several programs if you don't know how to handle this.)
HTH!
naneczek
Re: NXT PROBLEM
Post by naneczek »
task main() {
int y;
int i;
y = SensorUS(IN_4);
Wait(1);
while (true);
Sth like this? But shouldn't I use the clausule "loop" there anywhere?
Re: NXT PROBLEM
please use code tags!!
srry, I actually meant: as the 1st line in your loop, and you additionally will have to modify the loop condition:
so sth like this:
task main() {
  int y;
  int i;
  for (i=0;i<=100;++i) {
    y = SensorUS(IN_4);
  while (true);
naneczek
Re: NXT PROBLEM
Post by naneczek »
I've got another question. How to implement an array in this code which will save 100 measurements on the display, wait one second and repeat the measurements??
Sth like this isn't working:
task main() {
int y;
int i;
int MyArray[];
ArrayInit(MyArray,0,100);
y = SensorUS(IN_4);
NumOut(0,56, y, DRAW_OPT_CLEAR);
while (true);
Re: NXT PROBLEM
hey,
please use code tags for your code!
simple and stupid:
// *SNIP*
int myUSSvalues[100];   // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    y = SensorUS(IN_4);
    myUSSvalues[i]=y;   // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    if (i==99) Wait(1000);    // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
// *SNIP*
