[SOLVED]NXC Read/Write Help
jld001
Post by jld001 »
Here is my code: https://github.com/ArtskydJ/NXC_Tests/b ... String.nxc
//Read/Write String Test
  int what=0;
  unsigned int handle,fsize=1024,result;
  string outstring;
  TextOut(2,0,"make|delete|open",0);
  until (ButtonPressed(BTNLEFT)||ButtonPressed(BTNCENTER)||ButtonPressed(BTNRIGHT)) {}
  if (ButtonPressed(BTNLEFT))   {what=0;}
  if (ButtonPressed(BTNCENTER)) {what=1;}
  if (ButtonPressed(BTNRIGHT))  {what=2;}
  if (what==0)
    TextOut(0,48,"Writing",0);
    result=CreateFile("monkey.txt",1024,handle); //change to .dat later
    if (result==LDR_SUCCESS)
      TextOut(0,40,"Written!",0);
      Write(handle,"Joe is not a monkey...");
      Write(handle,"Joe is a human.");
      CloseFile(handle);
      PlayTone(500,500);
      Wait(500);
    else if (result==LDR_FILEEXISTS)
      TextOut(0,56,"FILE EXISTS",0);
      SendResponseNumber(MAILBOX10,result);
      TextOut(0,56,"UNKNOWN ERROR",0);
  else if (what==1)
    Wait(100);
    TextOut(0,48,"Deleting",0);
    result=DeleteFile("monkey.txt");
      {TextOut(0,40,"Deleted!",0);}
    else if (result=LDR_FILEISBUSY)
      TextOut(0,56,"FILE IS BUSY",0);
  else if (what==2)
    TextOut(0,48,"Reading",0);
    result=OpenFileRead("monkey.txt",fsize,handle);
      TextOut(0,40,"Read!",0);
      Read(handle,outstring);
      CloseFile(handle);
      SendResponseString(MAILBOX10,outstring);
      TextOut(0,24,outstring,0);
      PlayTone(2000,500);
      Wait(500);
    else if (result==LDR_FILENOTFOUND)
      TextOut(0,56,"FILE NOT FOUND",0);
  Wait(1000);
For some reason I do not see anything when trying to view after I create the file. Help?
EDIT:
BTW, the text file reads fine on the computer. I opened it in notepad++, and it showed the exact strings.
Why does it not read on the NXT?
Thanks in advance!
EDIT 2:
Also, when opened in notepad++, why are there 2 null terminators?
My Githubz of Source Codez, in order of awesomeness:
https://github.com/ArtskydJ/NXC_Source
My Lego Creations, in no particular order:
LEGO Bop-It - http://www.youtube.com/watch?v=6TsqrBVKbj0
LEGO Safe - http://www.youtube.com/watch?v=MyDRfVquHuY
Re: NXC Read/Write Help
I have no idea what's going wrong with your code. I seldom write or read files, but if, then I'm using the following dummy file i/o commands:
(instead of int use string mydata1,...):
// File I/O
void ReadFile() {
  string sFileName="myfile.dat";
  unsigned int nFileSize;
  byte fHandle;
  int IOresult;
  int mydata1, mydata2, mydata3, mydata4; // dummies
  IOresult = OpenFileRead(sFileName, nFileSize, fHandle);
  if (IOresult == LDR_SUCCESS) {
    ReadLn (fHandle, mydata1);
    ReadLn (fHandle, mydata2);
    ReadLn (fHandle, mydata3);
    ReadLn (fHandle, mydata4);  // ...oder Müller ...
    CloseFile(fHandle);
    TextOut(0,0,"FILE READ OK!");
  else   {
    TextOut(0,0,"FILE ERROR ! ");
void WriteFile() {
  string sFileName = "myfile.dat";
  unsigned int nFileSize = 256; // estimated file zize
  byte fHandle;
  int IOresult;
  DeleteFile(sFileName);
  IOresult = CreateFile(sFileName, nFileSize, fHandle);
    WriteLn (fHandle, mydata1);
    WriteLn (fHandle, mydata2);
    WriteLn (fHandle, mydata3);
    WriteLn (fHandle, mydata4);   // ...oder was...
    CloseFile(fHandle);
    TextOut(0,0, "FILE WRITE OK!  ");
  else  {
    TextOut(0,0, "FILE WRITE ERROR!");
maybe that might help you.
jld001
Post by jld001 »
I modified your code, and I found out that the nxt is ok with numbers, but does not like strings.
// File I/O
void ReadFile()
  byte fHandle;
  int IOresult;
  int mydata1, mydata2, mydata3, mydata4, mydata5, mydata6;
  /*string mydata1, mydata2, mydata3, mydata4, mydata5, mydata6;*/
    ReadLn (fHandle, mydata5);
    ReadLn (fHandle, mydata6);
    CloseFile(fHandle);
    NumOut(0,56,mydata1,0);
    NumOut(0,48,mydata2,0);
    NumOut(0,40,mydata3,0);
    NumOut(0,32,mydata4,0);
    NumOut(0,24,mydata5,0);
    NumOut(0,16,mydata6,0);
    TextOut(0,56,mydata1,0);
    TextOut(0,48,mydata2,0);
    TextOut(0,40,mydata3,0);
    TextOut(0,32,mydata4,0);
    TextOut(0,24,mydata5,0);
    TextOut(0,16,mydata6,0);
    while(1) {}
  else {TextOut(0,0,"FILE ERROR ! ");}
void WriteFile()
  unsigned int nFileSize = 1024; // estimated file zize
  byte fHandle;
  int IOresult;
  int mydata1=4, mydata2=8, mydata3=15, mydata4=16, mydata5=23, mydata6=42;  //lost :)
  if (IOresult==LDR_FILEEXISTS)
    WriteLn (fHandle, mydata5);
    WriteLn (fHandle, mydata6);
    CloseFile(fHandle);
    Wait(1000);
  else {TextOut(0,0, "FILE WRITE ERROR!");}
  WriteFile();
  ReadFile();
EDIT:
Maybe I'll write the letter's byte representations to a file and read the file and convert it back into a string. :)
hmm - I never used strings as data before.
...but maybe you try to represent a string by an array of char?
(maybe that's an issue about the " \0 termination" of strings vs. char arrays)
I would use the API functions designed for writing strings to files if I needed to write strings to a file such as WriteString or WriteLnString.
brilliant idea -
and I also stupidly completely forgot about
fputs, fprintf, and fgets :mrgreen:
jld001
Post by jld001 »
afanofosc wrote:I would use the API functions designed for writing strings to files if I needed to write strings to a file such as WriteString or WriteLnString.
Thank you!!! It's working now! :)
