Lego Color Sensor values
hello,
the meaning of color values I do actually understand (RGB, e.g. raw)
#define INPUT_RED 0
#define INPUT_GREEN 1
#define INPUT_BLUE 2
But what is a "blank value" for...?
#define INPUT_BLANK 3
Access the blank value from color sensor value arrays
and what means "number of entries"?
#define INPUT_NO_OF_COLORS 4
The number of entries in the color sensor value arrays
Re: Lego Color Sensor values
In full color mode, the FW stores the phototransistor values for when the LED is red, green, blue, and off. In full color mode, there are four LED states.
thx,
so "INPUT_BLANK 3" is sort of reflected background/ambient light?
but what's about "INPUT_NO_OF_COLORS 4"
AFAIK, yes.
Well, with red, green, blue, and blank, there are four "colors", hence "INPUT_NO_OF_COLORS 4"
well, actually no.
I mean:
Color sensor array indices
Input module constants
Constants for use with color sensor value arrays to index RGB and blank return values. More...
Macros
#define  INPUT_RED   0
so:
unsigned int ColorSensorRaw  ( byte  port, byte  color);
rawRed     = ColorSensorRaw(S1, INPUT_RED);
rawGreen   = ColorSensorRaw(S1, INPUT_GREEN);
rawBlue    = ColorSensorRaw(S1, INPUT_BLUE);
rawReflect = ColorSensorRaw(S1, INPUT_BLANK);
but what is THIS for?
rawNumber=  ColorSensorRaw(S1, INPUT_NO_OF_COLORS); //??????????
doc-helmut wrote:...
Where did you find that line of code? ColorSensorRaw doesn't compile if you pass the constant INPUT_NO_OF_COLORS into the second parameter.
# Error: compchk failed.  4 is not less than 4.
I still stand by my last reply.
See here.
my guess was simply, if
stands in a line with all the other constants for color macro names then it should be able to use it like the other macro constants and - above all - it should have any meaning or effect or result if it was passed to a function.
#define  INPUT_RED   0
why would one need a name for a constant equal to 4 which's name is as long as the hole Genesis if it has no other meaning than just "4" ?
Just to remember what "4" was like?
For the same reason people use "LCD_LINE1", "OUT_A", "S3", "INPUT_RED", or any other macros. You certainly are not required to use them, if you instead prefer to enter the numeric equivalence.
ok, thx, nevertheless
#define INPUT_RED 0
thoroughly make sense to prevent from confusing or reversing the inputs of the color sensor value array.
