RSO file structure
twodotzero
RSO file structure
Where can I find description of RSO file structure?
Re: RSO file structure
RSO files contain PCM or ADPCM mono samples with a default sample rate of 8k. You can look at my Pascal source code for converting from/to WAV format to/from RSO format.
http://bricxcc.svn.sourceforge.net/svnr ... RsoCvt.pas
The file starts with a short header containing 4 big-endian Words (8 bytes total). These are the format (0x0101 = adpcm, 0x0100 = pcm), the chunk size (total byes of sample data), the sample rate, and the play mode (ignored). So the file length will always be #sample bytes+8.
You can also look in the firmware source code, either as posted by LEGO or my enhanced version of that same code.
http://mindboards.svn.sourceforge.net/v ... /c_sound.c
See also the d_sound.c, d_sound.r, and d_sound_adpcm.r files for the low level details.
