Modulo Block for NXT version 2.0
gavilanp
Post by gavilanp »
With floating point math in the NXT software, it's no longer possible to compute modulo (no complaint about floating point ;) ).
Is there any available option for it, or an integer block which could then be used in a myblock to compute modulo.
thanks.
Re: Modulo Block for NXT version 2.0
Don't know of any custom blocks, but I think all you have to do is carry out the division then subtract the original number to get the decimal bit.
You may want to look into how to install the integer blocks.
http://www.teamhassenplug.org/NXT/NXTGAdditions.html
gavilanp
Post by gavilanp »
Steve, i put the integer math block on the palette and now i can compute modulo.
Thanks for pointing that to me, somehow I missed that although I had visited that page in my original search.
