NXC: detecting robot turns
floydbloke
Post by floydbloke »
Using NXC, driving a robot with two motors (let’s say B & C) I’m trying to determine the best way to detect when the robot turns.
My thoughts so far are to do a continuous comparison of the tachocount of B & C (with some tolerance I guess because I assume the two will never be exactly identical) , detecting the turn when the delta reaches a certain threshold.
I realise though that there is also a whole raft of other motor functions out there that I don’t fully understand the meaning of (especially those to do with synch) so if there is a more effective way to do this I would be keen to hear about it.
Re: NXC: detecting robot turns
Is the idea that you want it to detect a turn to correct itself?
floydbloke
mattallen37 wrote:Is the idea that you want it to detect a turn to correct itself?
No. I want to keep a record of the rotation count, logging it each time that the robot makes a turn.
For this issue I am starting a seperate task which does just the same what you already proposed:
calculate the delta count of both encoders.
task EncMonitor() {
  while(1) {
    long delta=(MotorRotationCount(OUT_B)-(MotorRotationCount(OUT_C)
    int threshold=1;
    if (delta>threshold) //... turn clockwise
    if (delta<threshold) //... turn anti clockwise
    Wait(3);
floydbloke
doc-helmut wrote:For this issue I am starting a seperate task which does just the same what you already proposed:
Thanks. That looks promising, will try it out at home tonight.
You'd need to keep resetting the encoders, or else use an offset for that to work (and fix the syntax).
yes, matt is right.
I wrote this from memory, I actually was comparing cached values
(encCounter - last_delta)
so I didn't need to reset the counters itself.
floydbloke
Both posts above understood (and they are common sense anyway :D )
floydbloke
partial success, had to tweak the code slightly as per below otherwise it would trigger when the motors are running at the same speed (i.e. delta == 0)
  while(1) {
    long delta=MotorRotationCount(OUT_B)-MotorRotationCount(OUT_C);
    int threshold=20;
    if (delta &&  delta>threshold)
    if (delta && delta<(threshold*-1))
  Wait(3);
testing this using the joystick tool in BrixCC and the motors spinning freely they obivously don't quite turn at the same speed and the threshold is exceeded after a few seconds. Might be different if they are robot-wheels and under (the same) load.
It does proof the concept though, and I can go certainly go forth from here with my little project.
Like I said before, you either need an offset, or you need to reset the encoders.
Something like this should work:
int threshold = 1;
long offset;
long delta;
while(1) {
  delta = MotorRotationCount(OUT_B) - MotorRotationCount(OUT_C) - offset;
  if (delta > threshold){
  else if (delta < (threshold * -1)){
  offset = delta;
  Wait(3);
Users browsing this forum: Semrush [Bot] and 30 guests
