NXC - problem with 2 color sensors
rlapie
Post by rlapie »
Hi all,
I added a color sensor to my robot and just for fun I wanted it to alternate between blue, green, red.
[ I use BricxCC, version 3.3.8.8 of 29/06/2010 ]
The code :
           counter ++ ;
           switch (counter)
                  case 1: SetSensorColorBlue(S3); break ;
                  case 2 : SetSensorColorRed(S3);break ;
                  case 3 : SetSensorColorGreen(S3); break ;
                  default : counter = 0 ; SetSensorColorNone (S3) ; break ;
This works fine !
Now I wanted to do the same with 2 color sensors, one attached to port S2 and the other to port S3
New Code :
           counter ++ ;
           switch (counter)
                  case 1: SetSensorColorBlue(S2);  SetSensorColorBlue(S3); break ;
                  case 2 : SetSensorColorRed(S2); SetSensorColorRed(S3); break ;
                  case 3 : SetSensorColorGreen(S2); SetSensorColorGreen(S3);  break ;
                  default : counter = 0 ; SetSensorColorNone (S2) ; SetSensorColorNone (S3) ; break ;
This doesn't work. The blue LED goes on and remains on.
Any idea anyone ?
Kind Regards,
Rudolf Lapie.
Re: NXC - problem with 2 color sensors
Post the whole code.
Rudolf,
Please post a small working program that demonstrates this issue. If it is a bug then it will be easier for John to hunt down.
pbenco
Post by pbenco »
Hello Rudolf
Perhaps have you forget to initialize the second color sensor?
Regards
pbenco
pbenco.wordpress.com/
I will try to run some tests this weekend with two color sensors to see if I can replicate the OP's problem.
