NXC - Reading temperature from TPA81
salgfrancisco
Post by salgfrancisco »
Hi, I recently got an NXT and I thought that using more sensors connected through i2c would bring a lot of new possibilities. So I got the TPA81 sensor in order to make a robot that would extinguish candles. (TPA81 datasheet here: http://www.robot-electronics.co.uk/htm/tpa81tech.htm ).
I was able to get everything connected in board, however I am not being successful in making the NXT read the sensor. I am programming in NXC and so far I got this:
// READ TPA81
#define TPA81_PORT IN_1
#define TPA81_ADDR 0xD0
         SetSensorType( TPA81_PORT, IN_TYPE_LOWSPEED );
         SetSensorMode( TPA81_PORT, IN_MODE_RAW );
         ResetSensor( TPA81_PORT );
         byte inbuf[10];
         byte nByteReady = 0;
        while( 1 )
                 while (I2CStatus( TPA81_PORT, nByteReady ) == STAT_COMM_PENDING);
                 I2CRead( TPA81_PORT, 10, inbuf );
                 NumOut( 0, LCD_LINE1, inbuf[3], DRAW_OPT_CLEAR_WHOLE_SCREEN );
But after downloading to the brick I keep getting File error! -1 whenever I try to run the program.
I have no idea what this means and would be glad if anyone could tell me where I am failing.
Thanks in advance ;)
Re: NXC - Reading temperature from TPA81
Try using this function to read the sensor:
void MyI2CRead(byte port, byte addr, byte reg, byte cnt, byte& outbuf[])
  byte cmdbuf[];  // register number holder
	int             loop;
  ArrayBuild(cmdbuf, addr, reg);
  loop = STAT_COMM_PENDING;              //Wait until bus is free
  while (loop == STAT_COMM_PENDING ){    //        ''
    loop = I2CStatus(port, nByteReady);  //        ''
  I2CBytes(port, cmdbuf, cnt, outbuf)    //Read the registers
So your program would look more like this:
// READ TPA81
	int             loop;
         SetSensorLowspeed(TPA81_PORT);
         byte inbuf[10];
        while( 1 )
                 MyI2CRead(TPA81_PORT, TPA81_ADDR, 0, 10, inbuf);
You need to be sure to use 82k pullups on the I2C lines (the recommended 1.8k pullups would be far too strong to use with the NXT).
salgfrancisco
Ok, so I tried your program but I keep getting the same File error! -1
I am starting to think this problem is somehow related to the NXT and not to the program. Any chance it might be the firmware version?
Could be. You should be running the latest enhanced FW (included with BricxCC). It's currently version 1.31. You should also make sure you are using a fairly recent version of BCC. I recommend you use the latest test release (I think it's 3.3.8.10).
salgfrancisco
So I reinstalled both the Enhanced Firmware and BCC but I keep getting the same error.
I added some ways to debug the program.
// READ TPA81
     TextOut( 0, LCD_LINE1, "MyI2cRead Was Called", DRAW_OPT_CLEAR_WHOLE_SCREEN );
   int             loop;
  TextOut( 0, LCD_LINE1, "Array Built... ", DRAW_OPT_CLEAR_WHOLE_SCREEN );
   TextOut( 0, LCD_LINE1, "Reading Temp      ", DRAW_OPT_CLEAR_WHOLE_SCREEN );
     TextOut( 0, LCD_LINE1, "Temp Read       ", DRAW_OPT_CLEAR_WHOLE_SCREEN );
         TextOut( 0, LCD_LINE1, "Program Started    ", DRAW_OPT_CLEAR_WHOLE_SCREEN );
         byte inbuf[10];
        while( 1 )
                 MyI2CRead( TPA81_PORT, TPA81_ADDR, 0, 10, inbuf );
                 TextOut( 0, LCD_LINE1, "Returned to Main   ", DRAW_OPT_CLEAR_WHOLE_SCREEN );
And now I can see that the error only pops up when I reach NumOut function to output the value. Any ideas?
Well, the function I gave you is the one I use to read just about any I2C device, so it shouldn't be buggy (well tested).
Instead of "NumOut( 0, LCD_LINE1, inbuf[3], DRAW_OPT_CLEAR_WHOLE_SCREEN );", try:
NumOut(0, LCD_LINE1, inbuf[3]);
Although that will probably also crash. It sounds like the array being returned isn't 10 elements long (so it throws an error when you try to use element 4, which doesn't exist).
Things to try:
Use the ArrayLen command to check the number of elements in the returned array.
Use NumOut with inbuf[0], and see if that throws an error (also try elements 1 and 2).
When you declare "byte inbuf[10];", do "byte inbuf[];" instead, and the I2C read function should size it for you.
I would try something like this:
  byte inbuf[] = {0xD0, 0x00};
  byte outbuf[];
  SetSensorLowspeed(S1, false); // uses LOWSPEED rather than LOWSPEED_9V
  while( true )
    while (I2CCheckStatus(S1) == STAT_COMM_PENDING)
      Wait(MS_1);
    byte count = 10;
    if (I2CBytes(S1, inbuf, count, outbuf ))
      NumOut(40, LCD_LINE1, count);
      if (count > 8) count = 8; // limit output to 8 lines
      for (int i=0; i < count; i++)
        NumOut(0, LCD_LINE1-(i*8), inbuf[i]);
      TextOut(0, LCD_LINE8, "error reading device");
salgfrancisco
I just tried what both of you said, and came to a few conclusions.
I used inbuf[]; without saying the length I wanted and after I2CRead I used ArrayLen() and found out that the array was only 1 byte long, meaning that I could only read inbuf[1] which was 0; So probably NXT isnt reading the sensor correctly.
Then I tried the code suggested by afanofosc and the output was always error reading device...
So I am guessing maybe I connected something wrong.
Here is a photo of the circuit
I even removed the pull-up resistors but so far no success.
The pullups are absolutely necessary. What values did you use?
BTW, mindsensors makes a nice NXT socket breakout for breadboarding with the NXT.
salgfrancisco
I connected the pull-up resistors (82k) again but it keeps not connecting to the TPA81. I tested the sensor with a Picaxe 28x2 microcontroller and it worked perfectly .
Users browsing this forum: No registered users and 91 guests
