I'm about to purchase a Samsung S i9000 Android mobile phone -
can I connect it (and how?) to one of these MS interfaces?
http://www.mindsensors.com/index.php?mo ... tion=73:73
Samsung S i9000 + Mindsensors
Re: Samsung S i9000 + Mindsensors
It will only work if you can upgrade it to Android 2.3.4 (or higher). This is required to be able to use the Google ADK. I know Mindsensors is also working on an alternative interface that will allow older versions of Android to work with it, but I don't have much detail on that.
For more info on the Google ADK, take a look here: http://developer.android.com/guide/topics/usb/adk.html
Perhaps you can flash it with Cyanogen Mod or another ROM.
Btw, you do realise that programming Android requires JAVA
I think it has 2.3.5 currently
but Java is an absurdity...
I was hoping I could use C/C++
edit:
and how will it be connected to the Mindstorms motor/sensor-interface? (and which?)
edit:
C++ on Android? I don't think so, unless you want to program that thing natively. If you think NXOS or nxtOSEK is hard, you ain't seen nothing yet.
You could program the ADK board with the Arduino environment or with AVRStudio in C or C++ without the use of the phone.
I think you need to do some research into programming for Android first. You can start here: [LINK].
b-b-b-baby...I w-was af-f-f-raid of that.^^...you ain't seen nothing yet
http://www.openelectrons.com/index.php? ... &PAGE_id=6
http://developer.android.com/sdk/ndk/overview.htmlmightor wrote:C++ on Android?
I think it still requires a bit of Java to act as "glue"
Yeah, it's not a whole lot different from the "ARMlets" concept that Palm used for their PalmOS 5 devices. It's only to speed certain things up and they're loaded much like .dll/.so's
