I am trying to write some C functions to read and write files to the NXT Brick. However, I am not entirely sure what the difference is between commands, .e.g write vs. write linear.
Does anyone know the difference?
Btw I'm looking at 'Appendix 1-LEGO MINDSTORMS NXT Communication protocol.pdf' in the NXT Bluetooth Developers Kit.
Communication Protocols Command Questions
Re: Communication Protocols Command Questions
Linear files are written across contiguous 256 byte blocks of flash memory. Non-linear files can span non-contiguous blocks of flash memory. RIC files and RXE|RTM|SYS files (all executables) must be linear. Other files can (and should) be non-linear. You can look at the BricxCC source code (in FantomSpirit.pas) to see how I use these different file types to write files to the NXT.
Thank you, John: this really helps! I'll definitely check out the source code too.afanofosc wrote:Linear files are written across contiguous 256 byte blocks of flash memory. Non-linear files can span non-contiguous blocks of flash memory. RIC files and RXE|RTM|SYS files (all executables) must be linear. Other files can (and should) be non-linear. You can look at the BricxCC source code (in FantomSpirit.pas) to see how I use these different file types to write files to the NXT.
Hello John (and everyone else),
I've been able to successfully write both *.rso and *.ric files with the open write data command. I've found that the brick will return an error if *.ric files are not written using the open write data command.
Now I'm trying to write a *.rtm file, e.g. Try-Touch.rtm, using the open write linear command (followed by a write command). The file does not previously exist on the brick. The error I keep getting is 0x84, where the Lego documentation says it means "End of File expected." I'm not entirely sure what to make of this error as I only receive it for the last data packet. I've posted the following output from my program that prints the data packet received from a write command (after open write linear has been sent successfully). The data packet is of the form
02--83--StatusByte--HandleNumber--LSB_WrittenBytes--MSB_WrittenBytes
and the output is below
02--83--00--00--3D--00
02--83--84--00--12--00
Any help would be most appreciated. Thanks.
RIC files definitely cannot be non-linear. They will not work when they are drawn if they are not contiguous in flash memory.
As you can see, I use the NoReply form of a system command for all the packets except for the last one. This code definitely works. And RIC files written as linear files draw correctly. You really should just use OpenWrite or OpenWriteLinear.
I checked the firmware source code also and the only time you get EOFEXSPECTED is if you try to write more bytes in the last packet than there is room left in the file. As you can see above, the last packet is smaller than all the other packets (assuming the size is not a multiple of 61).
function NameToNXTFileType(name : string) : TNXTFileType;
var
ext : string;
begin
Result := nftOther;
ext := AnsiLowercase(ExtractFileExt(name));
if (ext = '.rso') or (ext = '.rmd') then
Result := nftSound
else if ext = '.rdt' then
Result := nftData
else if (ext = '.ric') then
Result := nftGraphics
else if (ext = '.rxe') or (ext = '.sys') or (ext = '.rtm') then
Result := nftProgram
end;
size := aStream.Size;
if filetype in [nftProgram, nftGraphics] then
Result := NXTOpenWriteLinear(nxtFilename, size, handle)
else if filetype = nftData then
Result := NXTOpenWriteData(nxtFilename, size, handle)
Result := NXTOpenWrite(nxtFilename, size, handle);
if Result then
begin
// write in < 64 byte chunks
xferred := 0;
aStream.Position := 0; // start at the beginning
while xferred < size do
begin
cnt := Min(size - xferred, kNXT_MaxBytes-3);
// fill our buffer with the right number of bytes
for i := 0 to cnt - 1 do
aStream.Read(buf.Data[i], 1);
// write these bytes to the NXT
Result := NXTWrite(handle, buf, cnt, cnt = (size - xferred));
if not Result then Break;
inc(xferred, cnt);
end;
Result := NXTCloseFile(handle) and Result;
end;
function TFakeSpirit.NXTWrite(var handle: FantomHandle; const buffer: NXTDataBuffer;
var count: word; const chkResponse: boolean): boolean;
var
cmd : TNxtCmd;
b : byte;
len : integer;
begin
Result := Open;
if not Result then Exit;
cmd := TNxtCmd.Create;
try
if chkResponse then
b := kNXT_SystemCmd
b := kNXT_SystemCmdNoReply;
len := fLink.Send(cmd.MakeCmdWriteFile(b, kNXT_SCWrite, handle, count, buffer.Data));
if chkResponse then
begin
if len <> 3 then
begin
Result := False;
Exit;
end;
handle := fLink.GetReplyByte(0);
count := fLink.GetReplyWord(1);
end;
Result := len >= kRCX_OK;
finally
cmd.Free;
if fAutoClose then Close;
end;
end;
Thanks for your insights, John. I adjusted setting the last packet size and it works now. I've also been able to do this for reading files as wellafanofosc wrote: ...
Users browsing this forum: Semrush [Bot] and 37 guests
