NXT development framework?
Re: NXT development framework?
That's true, but I think we have to accept it as a given, as there's not much we can do about it... Hopefully it will still be useful even if there are long roundtrip times.
My philosophy is a bit different: Do something you like. If you're lucky, others will like it too. (this has worked for me)linusa wrote:The bottom line is of course to "do something better" than others, or provide something that doesn't exist yet.
back to the original thread... I can say for sure, if you want to do something with pbLua, Ralph (who wrote pbLua) will help you, and support you as much as possible.
To the question of motor functionality and syncing, pbLua uses code from the original LEGO firmware. So, it should work just as good as that firmware.
Sounds like a fun project.
Yep, that's why I'm doing it! I'm still having trouble getting Lua to talk to the serial port without blocking (I want to write a tool to easily concatenate and send Lua files to the brick), but it's been lots of fun so far!hassenplug wrote: My philosophy is a bit different: Do something you like. If you're lucky, others will like it too. (this has worked for me)
I'm going to put it up on https://github.com/skorokithakis/JellyLua (get it? pb and Jelly?) as soon as I have something that works in the slightest.
Don't get it :-/poromenos wrote: I'm going to put it up on https://github.com/skorokithakis/JellyLua (get it? pb and Jelly?)
"pb" stands for Peanut Butter, and often when people abbreviate it to pb they add "& Jelly" (or "and Jelly"), as in "PB&J sandwich". Since there is pbLua, he is calling this JellyLualinusa wrote:Don't get it :-/
Yep, exactlymattallen37 wrote:"pb" stands for Peanut Butter, and often when people abbreviate it to pb they add "& Jelly" (or "and Jelly"), as in "PB&J sandwich". Since there is pbLua, he is calling this JellyLua
Thanks for explaining the name
Though I've never actually used Lua, I came accross this language "MoonScript", which compiles to Lua. Maybe that's a cool thing for you? http://moonscript.org/
That looks very interesting, thank you! I don't want to introduce an unneeded dependency, but I'll make it so people can write in Moonscript and have it work with Jelly, thanks again!
