How to make a ini-file
wkohlenberg
Post by wkohlenberg »
I'm new on the forum and a have a question.
My question: "How can I make a ini-file?" I now how to make a txt-file.
If you have a more information, you can post it.
Meanwhile thanks for your time,
Walter.
(Sorry, I'm so bad in English.)
Re: How to make a ini-file
http://en.wikipedia.org/wiki/INI_file
The basic syntax is this:
[Section name]
Name=Value
OtherName=OtherValue ;this is a comment. it is ignored
wkohlenberg
Sorry, I mean: How to safe data (from the nxt) in an ini-file. I know how this can with a txt-file.
Well just use the normal functions to write to a txt file, but use the extension .ini
I may edit this later with better advice
wkohlenberg
timpattinson wrote:Well just use the normal functions to write to a txt file, but use the extension .ini
Oh, I know what you mean.
Thank you for your time and help.
[edit]
I have tryed your advice, but it don't work.
I have a ini-file, with the name objects. I have downloaded the file.
Now Read the code the file objects, but the code don't regonized the file.
the conclusion: Your advice don't work. Sorry
'Ini' files tend to be specific to the application. What application are you using that requires this file to be marked 'ini'?
linusa
Post by linusa »
wkohlenberg wrote: [edit]
His advice is correct. Ini files are text files. With a certain rule how this text should look. We can't help you if you don't post the files, the code, and exactly what you want to do!
[edit]
Are you programming in NXT-G or some other programming language? If you are using a text-based programming language like NXC then I would encourage you to post your source code so that we can help you correct the problems you are having. Send it to a compressed folder (aka .zip file) and attach it to your next post. Can I ask why you are wanting your NXT to create an ini file for you?
wkohlenberg
I'm programming in NXT-G.
I have a ini-file with the name objects. I download the ini-file to the NXT-brick. The NXT-G code read the file en write the first sentence of the file on the display, but there isn't.
It works when I make the ini-file to a txt-file.
linusa wrote: We can't help you if you don't post the files, the code, and exactly what you want to do!
wink wink nudge nudge ;)
