Idea: Visual NXC
Re: Idea: Visual NXC
Wow, it is really looking great!
I can hardly wait 'till it's "finished" (programs are never 100% finished ;)).
Nice new version...
2 things:
I get unhandled exceptions closing tabs in the nxc output
The "graph" thing in the enum editor is a bit cut off
Video quality is really crappy -- i deserve it for using windows movie maker :oops:
Exception text:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Visual_NXC.Forms.nxcOutput.tabBar1_SelectedTabChanged(TabItem obj)
at Visual_NXC.tabBar.set_selectedItem(TabItem value)
at Visual_NXC.tabBar.CloseCurrentTab()
at Visual_NXC.tabBar.tabBar_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Visual_NXC
Assembly Version: 0.1.0.0
Win32 Version: 0.1.0.0
CodeBase: file:///D:/Data/Downloads/0_1_0_5/Visual_NXC.exe
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
SpiderApplicationsToolkit
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.0
CodeBase: file:///D:/Data/Downloads/0_1_0_5/SpiderApplicationsToolkit.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
SyntaxHighlightingTextBox
Assembly Version: 1.0.2020.39164
Win32 Version: 1.0.2020.39164
CodeBase: file:///D:/Data/Downloads/0_1_0_5/SyntaxHighlightingTextBox.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
v-nxc-bugs.zip
Crappy screengrab of when i got the exception
(442.03 KiB) Downloaded 1023 times
May sound stupid but... you code won't compile.
How do i make it find the stuff you put in the DLL Libs.zip (apart form unzipping it of course ;) )
sidneys1
Post by sidneys1 »
timpattinson wrote:I get unhandled exceptions closing tabs in the nxc output
Thanks for finding that.. Fixed.
timpattinson wrote:The "graph" thing in the enum editor is a bit cut off
..because you are using XP. :| I really really hate XP. I'll look into it though, see what I can do.
timpattinson wrote:May sound stupid but... you code won't compile.
Ok, a quick crash-course on changing linked libraries work. First off, (assuming you're using Visual Studio) go to the solution explorer, expand "Visual_NXC", expand "References", and right-click and "Remove" the following entries: GlassLib, SpiderApplicationsToolkit, STP.RGI, and SyntaxHighlightingTextBox. (Nothing else!!)
Then, right-click "References":
Click the "Browse" tab, find the files you extracted from DLL Libraries.zip, and select them (this pic is incorrect, bin/debug/ doesn't exist, but you get the idea):
Then hit ok. Things should compile fine now.
Have a nice day,
~Sidneys1
sidneys1
Post by sidneys1 »
Thought I'd make a quick post on my progress... Our internet went out today, and I had nothing to do, so I did some major redesigning and work on Visual NXC. 0.1.0.6 is gonna be cool :D
The new 'blocks' render faster, and are made in a four-step process:
Have a nice day,
~Sidneys1
Yes i did finally get vs2010 from Dreamspark.
I'm using it for a school project so the school IT guys installed it for me.
It worked.
Is it possible to mirror the Mercurial repository to the SVN repository so I don't have to install Hg to get the most up-to-date code :?:
timpattinson wrote:Is it possible to mirror the Mercurial repository to the SVN repository so I don't have to install Hg to get the most up-to-date code :?:
*gasp!* :o Why would you want to do such a thing!? (Not install TortoiseHg or Mercurial.)
But, if you insist, look here. :cry:
Just do this in SVN:
svn checkout http://bitbucket.org/Sidneys1/visual-nxc/trunk
Because then i have to get permission from the IT guys at my school and they won't let me as it's not school related :evil: :x :x :x
EDIT: It didn't work:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\pattinsont>cd Desktop/visualnxc
C:\Documents and Settings\pattinsont\Desktop\visualnxc>svn co http://bitbucket.org/Sidneys1/visual-nxc/trunk
svn: Repository moved permanently to 'https://bitbucket.org/Sidneys1/visual-nxc/trunk'; please relocate
C:\Documents and Settings\pattinsont\Desktop\visualnxc>svn co https://bitbucket.org/Sidneys1/visual-nxc/trunk
svn: '/repos12/r-276129/!svn/vcc/default' path not found
sidneys1
Post by sidneys1 »
Sorry, can't really help you there, Tim. PMing Muntoo seems your best bet, but I don't know much about Mercurial/SVN.
Anyhow, here's a small update.. I got drag-dropping mocked up nicely, and even got it to 'nest' nicely!
Have a nice day,
~Sidneys1
