Wouldn't this block all GIFSmuntoo wrote:Code: Select all
sourceforge.net##IMG[src^="./download/file.php?avatar=*.gif"]
Change rules
Re: Change rules
Re: Change rules
"burns with the heat of a thousand suns" - I like that!
Re: Change rules
That's why you don't mess with the Banhammer kids!mightor wrote:All 4 of the founders of this board have a hatred for animated avatars that burns with the heat of a thousand suns.
P.S. This is what Mr. Mighty Mightor looks like when angry. Nice mustache BTW.
haydenstudios
Re: Change rules
Xander just wrote: If you do see swearing happening on these forums, report the post. If it's bad enough I will deal with the offender.
...However, on a different topic in the open discussion forum, Xander wrote:Now I'll quit ***ching about NXC as soon as John finishes implementing function overloading.
evidence
-Hayden
Re: Change rules
@mightor Can you post a video of you hitting your head with the banhammer?
EDIT: I can't post if the post begins with '@'. Only if it's ' @'.
Re: Change rules
Exactly... remember the earlier discussion about that?muntoo wrote:...EDIT: I can't post if the post begins with '@'. Only if it's ' @'.
Re: Change rules
Maybe the Open Discussion forum doesn't count.haydenstudios wrote:Xander just wrote: If you do see swearing happening on these forums, report the post. If it's bad enough I will deal with the offender.However, on a [url=https://sourceforge.net/apps/phpbb/mindboards/viewtopic.php?f=1&t=556&p=4894&hilit=bitching#p4894]different topic in the open discussion forum[/url], Xander wrote:Now I'll quit ***ching about NXC as soon as John finishes implementing function overloading
haydenstudios
Re: Change rules
Are you saying that everything is tolerated in the open discussion forum? Xander wrote in an open discussion topic:studbrickmaster wrote:Maybe the Open Discussion forum doesn't count.haydenstudios wrote:Xander just wrote: If you do see swearing happening on these forums, report the post. If it's bad enough I will deal with the offender.
- Xander...However, on a different topic in the open discussion forum, Xander wrote:Now I'll quit ***ching about NXC as soon as John finishes implementing function overloading.
- Xander![]()
evidence
It applies to the open discussion forum.Xander wrote: Flaming or trolling will not be tolerated on these forums.
-Hayden
Re: Change rules
Guys, you better cut down on those large quotations before doc gets !@#$ing angry! (Joking.
I'd like them cut down, too, of course.)
haydenstudios
