[NXC] convert float to int
Is it possible to convert a float number to an integer (rounding the number to floor or ceil), becoming an integer after the operation?
From what I searched and tried, using floor() or ceil() just rounds the number, but the returning value is still a float. I'm trying to pass an integer argument to a function, that had to be calculated as a float before.
The specific example is: I have the expression "angle = 112.5*X". After calculating the angle I want to send the closest integer to PosRegSetAngle(). If I just use floor() or ceil() it doesn't work.
Re: [NXC] convert float to int
This should do the conversion:
C-Style casts should go on the wishlist...
You don't need to explicitly (or "explicitly-implicitly", in this case
) convert
This works fine:
#define f2i(x) float2int(x)
int float2int(float x)
return(x);
if(sin(f2i(1.5)) == sin(1.5))
TextOut(0, 0, "You should not see this text.", 0);
int(x)
float
to int
when passing arguments of a different type (in NXC).This works fine:
int add(int a, int b)
return(a + b);
NumOut(0, 0, add(19.84, 23.999)); // Prints 42
Hm, I just noticed the following behaviours:
I hope that can be useful for some debugging.
float a = 2.5;
int b = 1;
long c = a*b; // c is equal to 2
float a = -2.5;
int b = 1;
long c = a*b; // c is equal to 0
float a = 2.5;
int b = -1;
long c = -2.5; // c is equal to -2
int a = 2.5;
int b = -1;
long c = a*b; // c is equal to -2
float a = 2.5;
float b = -1;
float a = -2.5;
float b = -1;
c = -3;
, though.)Code: Select all
float a = 2.5;
int b = -1;
I think that may solve some bugs in one of my programs...
the mathematically correct way to round a fp value to an integer is this one:
or, nested:
HTH!
inline long round(float f)
if (f>=0) return (f + 0.5);
else return (f - 0.5);
return (f>=0? f+0.5 : f-0.5);
Technically, the
round()
method is usually implemented as such:
inline long round(float x)
return(x + 0.5);
I'm not that worried about the rounding. The incorrect cast is quite a big issue, I would say.
I worked around the problem in my program right now, but I will certainly get stuck with this later again, trying to understand what is wrong. I hope John had the chance to look at this topic.
ok, but:muntoo wrote:Technically, theround()
method is usually implemented as such:Code: Select all
inline long round(float x) { return(x + 0.5); }
1.) then what's not working for the TO's float conversion?
2.) what's about negative fp values?
What do you mean by "it doesn't work"? Do you get a compiler error or the wrong value? Can you post a simple example that shows what is going wrong?ricardocrl wrote: The specific example is: I have the expression "angle = 112.5*X". After calculating the angle I want to send the closest integer to PosRegSetAngle(). If I just use floor() or ceil() it doesn't work.
Could you please post the F12 code listing for these snippets. Is it possible that you have an old compiler version? Here's what the latest compiler produces:ricardocrl wrote: Hm, I just noticed the following behaviours:
float a = 2.5;
int b = 1;
// mov __main_7qG2_a_7qG2_001, __constValf2P5
// mov __main_7qG2_b_7qG2_001, __constVal1
// mul __main_7qG2_c_7qG2_001, __main_7qG2_a_7qG2_001, __constVal1
float a = -2.5;
int b = 1;
// mov __main_7qG2_a_7qG2_001, __constValNegf2P5
float a = 2.5;
int b = -1;
// mov __main_7qG2_b_7qG2_001, __constValNeg1
// mul __main_7qG2_c_7qG2_001, __main_7qG2_a_7qG2_001, __constValNeg1
// mov __main_7qG2_c_7qG2_001, __constValNegf2P5
int ai = 2.5;
int b = -1;
long c = ai*b; // c is equal to -2
// mov __main_7qG2_ai_7qG2_001, __constValf2P5
// mul __main_7qG2_c_7qG2_001, __main_7qG2_ai_7qG2_001, __constValNeg1
float a = 2.5;
float bf = -1;
long c = a*bf; // c is equal to 0
// mov __main_7qG2_bf_7qG2_001, __constValNeg1
float a = -2.5;
float bf = -1;
long c = a*bf; // c is equal to 2
