Statements about LEGO lamp brick for NXC
Help!
What are the NXC statements for the LEGO lamp brick? How to control the functions such as on, off or blinking?
I cannot find these statements in the NXC Programmer's Guide.
YH Chan
YH Chan
Re: Statements about LEGO Light Brick for NXC
Light brick? Do you mean the light sensor light? Use these lines to turn the light on and off:
If you are referring to the actual 9v light, you use it on the motor port, so the controls are exactly the same as the motors (OnFwd, and Off).
SetSensorType(S1, SENSOR_TYPE_LIGHT_ACTIVE); //Turn on the light
SetSensorType(S1, SENSOR_TYPE_LIGHT_INACTIVE);//Turn off the lightMatt
Matt,
Sorry!
I mean the LEGO lamp brick, not the NXT Light Sensor or old RCX Light Sensor.
I try to use the following program, but no affect.
YH Chan
Sorry!
while(true)
SetSensorType(OUT_A, SENSOR_TYPE_LIGHT_ACTIVE); //Turn on the light
Wait(1000);
SetSensorType(OUT_A, SENSOR_TYPE_LIGHT_INACTIVE);//Turn off the light
Wait(500);
Can you give a BL URL to it? I have no idea what lamp brick you are talking about...chanyh wrote:...I mean the LEGO lamp brick...
YH Chan
Do you mean the new PF LEDs? You use those with the motor port, so you would turn them on and off like a motor.
I don't remember any lamp brick, other than the RCX one. Maybe there were some from the 12v train days, or the 4.5v sets...
Re: Statements about LEGO lamp brick for NXC
The lamp brick is the Electric, Light Brick 1 x 2 with Single Top Light.
The URL link is : http://www.bricklink.com/catalogItem.asp?P=4767
YH Chan
YH Chan
Okay, that is a 9v lamp, same as the RCX one, only this one you can reverse the polarity to make it flash (not really a necessary feature when being controlled by the NXT
To use it, use an NXT -> RCX converter wire in a motor port. Use the motor commands to turn it on and off.
From the the LEGO Mindstorms website, one can download a Lamp* block in the package of Legacy_Blocks. This block can control a lamp.
I want to control the lamp by NXC statements.
YH Chan.
YH Chan.
So use the OnFwd/OnRev and the Off/Coast commands.
Hi, Matt,
Thanks!
I use the commands that you suggested. It works.
YH Chan.
Thanks!
YH Chan.
Users browsing this forum: Semrush [Bot] and 38 guests
