Lego USB thumb drive
Discuss anything and everything. Keep it clean (or else).
I recently made a USB drive into a Lego USB drive :). Thought I'd post some pictures here to inspire other to do the same. The drive I used is a 4GB HP v165w. I'm still figuring out my dremel, so it's a bit scratched here and there, and the bricks don't quite line up. I have pictures here.
Re: Lego USB thumb drive
Wow, that looks pretty cool ;) Thanks for sharing!
Looks very pro! Nice job!
sidneys1
Post by sidneys1 »
Excellent job! I really ought to do that with my old Lexar Firefly, if I can fit it...
Have a nice day,
~Sidneys1
Thanks for all the positive comments, but it really actually doesn't look that good when you are holding it :P. I'm hoping to get a bit more practice with my dremel, then maybe I'll another few for friends.
sidneys1 wrote:Excellent job! I really ought to do that with my old Lexar Firefly, if I can fit it...
I use a Lexar Firefly for music in the car, I like the nice blue glowing end. I imagine you could fit it in a 3x2 block with a 2x2 for a cap. Or, (great idea that just came to me now :)) you could stick two 1x2 blocks top to bottom for the USB stick with a 1x2 for a cap. Not sure if that makes sense, I can draw it up if it doesn't.
sidneys1
Post by sidneys1 »
nxtreme wrote:I use a Lexar Firefly for music in the car, I like the nice blue glowing end. I imagine you could fit it in a 3x2 block with a 2x2 for a cap. Or, (great idea that just came to me now :)) you could stick two 1x2 blocks top to bottom for the USB stick with a 1x2 for a cap. Not sure if that makes sense, I can draw it up if it doesn't.
Nice idea! I may try that sometime. Maybe I could use a transparent 1x2 block for the end so that the blue glow shows through :)
Have a nice day,
~Sidneys1
*EDIT: Or rather, a transparent 1x1 plate, since the studs would have to face the USB end for the cap to do its job.
sidneys1 wrote:Nice idea! I may try that sometime. Maybe I could use a transparent 1x2 block for the end so that the blue glow shows through :)
Great idea! If you remove the USB sticks cover, the LED light might not be quite as diffused, but a dab of hot glue would solve that.
