NeXT Commander
savedcoder
NeXT Commander
Post by savedcoder »
Hello NXT fans,
I have written a program that you might be interested in. It is called NeXT Commander, and it is A program to control every aspect of the Mindstorms NXT.
Its features include:
  • File management
  • Sensor monitoring
  • Firmware downloading
  • Remote-control
  • USB and Bluetooth support
  • More speed than NXT-G
  • NXT renaming
  • More coming...
Check it out at: http://nextcommander.sourceforge.net, http://www.softpedia.com/get/Others/Mis ... nder.shtml
NeXT Commander is in alpha phase, so please, report all bugs! Feature requests, criticisms, etc. are also welcome.
Hope you find it useful,
SavedCoder
To God be the glory, great things He has done;
So loved He the world that He gave us His Son,
Who yielded His life an atonement for sin,
And opened the life gate that all may go in.
Re: NeXT Commander
Wow, that looks pretty cool!
Re: NeXT Commander
I found a bug!
When I connect via BT and click monitor Sensor button, it goes back to the "Choose NXT to Command" screen
I click on my nxt and it goes back to the other screen
I'm running XP SP3.
-tim
savedcoder
Re: Re: NeXT Commander
Hi Tim,
What Bluetooth software you are running? (Widcomm, Microsoft, other?) Are you using NXT 1 or 2? Does it return to the selection screen immediately after you click Monitor Sensor, or after you select a sensor and click Start Monitoring? If it's after you select a sensor and click Start Monitoring, what sensor did you select?
savedcoder wrote:Hi Tim,
I'm running Widcomm bluetooth software on my HP laptop with NXT 2.0.
I got the drivers from NXT-G 1.1 Educational
It's just after i click Start Monitoring that it returns to the selection screen. I didn't see any sensor selection box.
Good luck.
-Tim
ps. if you want me to run a debugger or something just Private Message me (PM button next to my avatar)
bullestock
Re: NeXT Commander
Post by bullestock »
Looks nice.
Note that, to comply with SF licensing terms, you must provide the source code too.
savedcoder
Re: NeXT Commander
I did. It's in the src folder in whatever folder you install it to.
Re: NeXT Commander
savedcoder wrote:I did. It's in the src folder in whatever folder you install it to.
Of course, it's "awesomer" to use SVN for this kind of stuff. :)
i-fixed-it-44
Re: NeXT Commander
Post by i-fixed-it-44 »
I downloaded it and it wont install,I have a mac version 10.4.11
Re: NeXT Commander
i-fixed-it-44 wrote:I downloaded it and it wont install,I have a mac version 10.4.11
Have you tried it with WINE?
