TEST Thread - play with tags and signatures here
Re: TEST Thread - play with tags and signatures here
ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrst
Hopefully all this works out well....
C, C++, Java, BASIC, Fortran and now... NXC?
To all those who have faithfully restarted the NXTASY site, I would like to say a big thank you!
Also, I'm finally back, after a 10-month long absence... For exams.
Hey, muntoo -
Can you draw like this?!?!
Dud "Paint" Master
Dud "Paint" Master
2Labz.com, My Website
I can draw... better.dudmaster wrote:Hey, muntoo -
Dud "Paint" Master
I'm planning on fixing this later (using some JavaScript skillz, or if I can figure out how to make plugins for GIMP/Paint.NET to generate the green web thingy at the bottom right corner as good as I'd like it to be...), but here's one image:
Or are you talking about pure MS Paint? I've got many from when I was 9 years old or younger:
What all did you use to make that? I used PDN.
The first one was 99% PDN (1% GIMP for a little alpha masking), and the other 3 were pure MS Paint.dudmaster wrote:What all did you use to make that? I used PDN.
Just testing stuff
~@Does this work?
_@Matt: yes
snorri@rimu:~$ sudo emacs /etc/resolv.conf
We assume you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
Password:
snorri is not in the sudoers file. This incident will be reported.
snorri@rimu:~$I'm still laughing...
haydenstudios
Well, most of the things can be tested with the preview button, but heres something that I think cannot be tested with the preview button. I've wanted to test this for a while, and I think that this might be the appropriate place to test it. Here it goes:
Hallo Helmut dort, wenn Sie lesen und verstehen können diese dann bitte sag es mir. Ich weiß nicht wirklich sprechen Deutsch, ich spreche nur Englisch. Der einzige Grund, dass ich Deutsch schreibe ich ist, dass ich mithilfe von Google übersetzen. Bin ich effektiv kommunizieren Sie auf Deutsch?
EDIT: If any of you admins do not tolerate the usage of languages other than english, then do not hesitate to tell me. Upon the notification of this, I will delete this post.
-Hayden
that's quite good understandable. This is the re-translation and I guess it hits your original text quite good:Hallo Helmut dort, wenn Sie lesen und verstehen können diese dann bitte sag es mir. Ich weiß nicht wirklich sprechen Deutsch, ich spreche nur Englisch. Der einzige Grund, dass ich Deutsch schreibe ich ist, dass ich mithilfe von Google übersetzen. Bin ich effektiv kommunizieren Sie auf Deutsch?
yes, you are :)Hello Helmut there if you can read and understand this then please tell me. I do not really speak German, I speak only English. The only reason that Iamwrite German,I writeis that I translated using Google. Am Iameffectivelyyoucommunicateing with you in German?
Users browsing this forum: Ahrefs [Bot] and 7 guests
