NXC: set / change Brick name?
how can I change the Brick name?
To read it, string s=BrickDataName() works.
To change it, I expected sth like "SetBrickDataName" but couldn't find anything... :?
Re: NXC: set / change Brick name?
I usually change it from inside whatever programming environment I am in. You can do it from inside BrixCC, ROBOTC and NXT-G and probably one of the tools that comes with Lejos, too.
how? (by Bricxcc?)
Tools->NXT Screen
congratulations!
read good hidden easter egg... ;)
Perhaps there is an easier way to do this, but I'm not aware of it :)
I think you can change it the data panel section of the communication/ memory block in NXT-G as well.
That is correct but the question was for BrixCC.
mightor wrote:Perhaps there is an easier way to do this, but I'm not aware of it :)
no, thx a lot, it's fine!
I only had to do it once because one of my nxts was suddenly "kaputt" and has been exchanged the Lego technical support.
Now already everything again is "in the green sector" :D
Some of the "BricxCC->Tools->???" work too. I think the best one for the job was "Diagnostics", IIRC.
