NXTasy NXT-G blocks?
i-fixed-it-44
I was wondering if there was anyway to get all the NXT-g blocks from nxtasy to mindboards or if there is any other place where they can be downloaded or used again because I need some of them for some projects I'm going to do.
Re: NXTasy NXT-G blocks?
I believe there was a thread on this a few weeks ago. The answer is it depends. Nxtasy was seen as the repository for blocks and, as such, most of the blocks are lost unless you can contact the person who originally posted them. However, some blocks were just linked in the repository and they may still be available wherever they were originally posted. Others were not unique and similar blocks have been created elsewhere. If you could state the purpose of the blocks you require it would be easier to help you find them.
i-fixed-it-44
I need the memory block,I that makes it easier and some other blocks would've been good to but i forget there names.h-g-t wrote:I believe there was a thread on this a few weeks ago. The answer is it depends. Nxtasy was seen as the repository for blocks and, as such, most of the blocks are lost unless you can contact the person who originally posted them. However, some blocks were just linked in the repository and they may still be available wherever they were originally posted. Others were not unique and similar blocks have been created elsewhere. If you could state the purpose of the blocks you require it would be easier to help you find them.
Someone from Mindboards posted code and blocks here :- http://www.mindboards.net/NXTG
What did the 'memory block' do?
If you can provide details of what the blocks did or even the functions you need it would be easier to help.
i-fixed-it-44
I got the other ones I needed but I couldn't find the memory block what it does is it reads the amount of memory on the nxt I was going to use it for a NeXT Coke Machine.h-g-t wrote:Someone from Mindboards posted code and blocks here :- http://www.mindboards.net/NXTG
This NXT-G program uses a block which is measuring the amount of memory :-
http://us.mindstorms.lego.com/en-us/Com ... 8e1c869cda
Don't know if it is the same block but it might do what you want.
If not, there is a project by dudmeister on NXTlog which uses the NXTasy memory block - he refers in another project to help from haydenstudios, and there is a Mindboards member by that name. If they are one and the same then perhaps he could put you in contact with dudmeister.
Recently updated- box.net/mindboards. If you go to "Main Repository\NXT-G Blocks\" there is quite a lot there.
PS Some people are uploading a rbt with the block in the program. This Will Not Work! To use a block in your program you need to have uploaded the ZIP file to your palette with the Block Import and Export Wizard. If you do not have a block in your palette that is being used in a program you have opened, it will appear blue with a messed up config panel and the name of the block on it (like a My Block). If you own a block and you would like to post it online, you ether need to have a ZIP file that the creator of the block put the files into or you can export a block by going to the Block Import and Export wizard. Click on the 'Manage' tab, select the block you want and click on export to save the fil to your computer. if it is not zipped, do so before you upload it. Any questions, you can reply to this message or PM me.
Hope this helps.
Update: http://nxtguide.yolasite.com/managing-blocks.php
Hope this helps.
