so you need only 1 controller (muxer)?I wish I had one of each of these controllers so I could test this code
and what about the encoders attached to that controller?
but back to the error code -32:
what does that mean?
#define printf5( _x, _y, _format1,_format2,_format3,_format4,_format5,_value1,_value2,_value3,_value4,_value5) { \
string sval2 = FormatNum(_format2, _value2); \
string sval3 = FormatNum(_format3, _value3); \
string sval4 = FormatNum(_format4, _value4); \
string sval5 = FormatNum(_format5, _value5); \
string s =sval1+sval2+sval3+sval4+sval5; \
TextOut(_x, _y, s); \
void TXMotorOn(byte NXTport, byte TXmotor, char percentage)
byte retLen = 0;
int i, j;
char modeMsg[];
char powerMsg[];
byte devAddr, modeReg, powerReg;
char IOresult;
// addresses and registers
devAddr = (TXmotor+2)&14;
modeReg = 0x44 + (TXmotor % 2)*3;
powerReg= 0x45 + (TXmotor % 2);
ArrayBuild(modeMsg, devAddr, modeReg, 0);
ArrayBuild(powerMsg, devAddr, powerReg, percentage);
// Send the first message as soon as the bus is ready
TextOut(0,56,"M Rg md pow error");
while ((I2CCheckStatus(NXTport) == STAT_COMM_PENDING) && (I2CCheckStatus(NXTport) != NO_ERR)) Wait(1);
IOresult=I2CWrite(NXTport, retLen, modeMsg);
if (IOresult != NO_ERR)
{ printf5(0,48-(8*TXmotor),"%d","%3d","%2d","%5d","%4d",TXmotor,modeMsg[1],modeMsg[2],powerMsg[2],IOresult);
return; } // for Error debug
// Send the second message when the first one is done
IOresult=I2CWrite(NXTport, retLen, powerMsg);
task main(){
SetSensorType(S1, SENSOR_TYPE_LOWSPEED);
ResetSensor(S1);
Wait(20);
TXMotorOn(0, 0, 50);
TXMotorOn(0, 1, 20);
Wait(2000);
TXMotorOn(0, 0, 0); // brake
TXMotorOn(0, 1, 0); // brake
Wait(2000);
TXMotorOn(0, 0, -50);
TXMotorOn(0, 1, -20);
Wait(2000);
TXMotorOn(0, 0, 0); // coast
TXMotorOn(0, 1, -128); // brake
Wait(2000);
while (true);
}Code: Select all
reg v.type meaning
44H byte Motor 1 mode
45H s/byte Motor 1 power
46H s/byte Motor 2 power
47H byte Motor 2 mode
40H–43H s/long Motor 1 target encoder value, high byte first
48 –4BH s/long Motor 2 target encoder value, high byte first
4C –4FH s/long Motor 1 current encoder value, high byte first
50 –53H s/long Motor 2 current encoder value, high byte first
long GetTXMotorCounter(byte NXTport, byte TXmotor)
byte devAddr;
byte bufLen = 4; // <===== 4 byte for long ?????
byte encbuf[]; // <===== array of 4 bytes ?????
long IOresult;
byte i2cMsg[];
long counter;
if (TXmotor==0) {
ArrayBuild(i2cMsg, devAddr, 0x4C,0x4D,0x4E,0x4F, encbuf); // <===== ?????
if (TXmotor==1) {
ArrayBuild(i2cMsg, devAddr, 0x50,0x51,0x52,0x53, encbuf); // <===== ?????
IOresult= I2CRead(NXTport, bufLen, i2cMsg); // <===== ????? need to wait until no i2c IOresult error?
counter=.....? // <===== ????? long counter out of 4 single bytes?
return(counter);
}Code: Select all
*SNIP*
if (TXmotor==0) {
*SNIP*Code: Select all
long _DGPSreadRegister(byte link, unsigned byte command) {
const byte msgLen = 4;
byte sendMsg[];
byte replyMsg[];
ArrayBuild(sendMsg, DGPS_I2C_ADDR, command); // <-- you will need to modify that into something like this:
// ArrayBuild(sendMsg, DGPS_I2C_ADDR, START_OF_ENCODER_REGISTER); // Only -one- register, the first one, is requested
while ((I2CCheckStatus(link) == STAT_COMM_PENDING) && (I2CCheckStatus(link) != NO_ERR)) Yield();
if(!I2CBytes(link, sendMsg, msgLen, replyMsg))
return 0;
// Reassemble the messages, depending on their expected size.
return replyMsg[3] + (replyMsg[2] << 8) + (replyMsg[1] << 16) + (replyMsg[0] << 24);
}Users browsing this forum: Semrush [Bot] and 23 guests
