PSP-Nx v3 Button Problem
dudmaster
Post by dudmaster »
Hello all, I am having trouble with the buttons on the PSP controller. I am using NXC, and i am using the button "PSP_BTNSET2_SQUARE"
and the command ReadSensorMSPlayStation(); command. I have it in Analog mode.
I have some code:
until(b2 == BTN_SET2_SQUARE);
...And that doesn't work.
Does anybody know the problem?
2Labz.com, My Website
Re: PSP-Nx v3 Button Problem
I use something like this for reading buttons. Note, it uses very different specifics than what I currently use, but the concept is similar.
int sel,str,up,dwn,lft,rght,L2,R2,L1,R1,tri,cir,crs,squ,sl,sr,b1,b2,B1,B2,lx,ly,rx,ry;
  SetSensorLowspeed(S3);
  while (true)
    ReadSensorMSPlayStation(S3, 0x02, b1, b2, lx, ly, rx, ry);
    B2=b2*(-1)+255;
    if (B2>=128){squ=1;B2=B2-128;}else{squ=0;}
    if (B2>=64){crs=1;B2=B2-64;}else{crs=0;}
    if (B2>=32){cir=1;B2=B2-32;}else{cir=0;}
    if (B2>=16){tri=1;B2=B2-16;}else{tri=0;}
    if (B2>=8){R1=1;B2=B2-8;}else{R1 =0;}
    if (B2>=4){L1=1;B2=B2-4;}else{L1 =0;}
    if (B2>=2){R2=1;B2=B2-2;}else{R2 =0;}
    if (B2>=1){L2=1;B2=B2-1;}else{L2 =0;}
    B1=b1*(-1)+255;
    if (B1>=128){lft=1;B1=B1-128;}else{lft=0;}
    if (B1>=64){dwn=1;B1=B1-64;}else{dwn=0;}
    if (B1>=32){rght=1;B1=B1-32;}else{rght=0;}
    if (B1>=16){up=1;B1=B1-16;}else{up=0;}
    if (B1>=8){str=1;B1=B1-8;}else{str=0;}
    if (B1>=4){sr=1;B1=B1-4;}else{sr =0;}
    if (B1>=2){sl=1;B1=B1-2;}else{sl =0;}
    if (B1>=1){sel=1;B1=B1-1;}else{sel=0;}
    ClearScreen();                        //    ___________________
    NumOut(15,60,L2);                     //   | L2*           *R2 |
    NumOut(78,60,R2);                     //   | L1*           *R1 |
    NumOut(15,50,L1);                     //   |  up          tri  |
    NumOut(78,50,R1);                     //   |   *   selstr  *   |
    NumOut(78,35,tri);                    //   |lft     * *     cir|
    NumOut(93,20,cir);                    //   |*     *rght *squ  *|
    NumOut(78,0,crs);                     //   |  dwn sl   sr crs  |
    NumOut(63,20,squ);                    //   |   *   *   *   *   |
    NumOut(40,30,sel);
    NumOut(35,0,sl);
    NumOut(58,0,sr);
    NumOut(53,30,str);
    NumOut(15,35,up);
    NumOut(30,20,rght);
    NumOut(15,0,dwn);
    NumOut(0,20,lft);
    NumOut(21,LCD_LINE1,ly);
    NumOut(21,LCD_LINE2,lx);
    NumOut(50,LCD_LINE1,ry);
    NumOut(50,LCD_LINE2,rx);
b1 series
sel      =1
sl       =2
sr       =4
str      =8
up       =16
rght     =32
dwn      =64
lft      =128
b2 series
L2       =1
R2       =2
L1       =4
R1       =8
tri      =16
cir      =32
crs      =64
squ      =128
dudmaster
Post by dudmaster »
Well, thanks a lot. I got my program to work using this "sub" program. THX! Dud
You're welcome, but it is not as efficient as it could be. If you do something like this, it would be more efficient.
    B2=~b2;
    squ = (B2 >> 7) & 0x01;
    crs = (B2 >> 6) & 0x01;
    cir = (B2 >> 5) & 0x01;
    tri = (B2 >> 4) & 0x01;
    R1  = (B2 >> 3) & 0x01;
    L1  = (B2 >> 2) & 0x01;
    R2  = (B2 >> 1) & 0x01;
    L2  = (B2 >> 0) & 0x01;
    B1=~b1;
    lft = (B1 >> 7) & 0x01;
    dwn = (B1 >> 6) & 0x01;
    rght= (B1 >> 5) & 0x01;
    up  = (B1 >> 4) & 0x01;
    str = (B1 >> 3) & 0x01;
    sr  = (B1 >> 2) & 0x01;
    sl  = (B1 >> 1) & 0x01;
    sel = (B1 >> 0) & 0x01;
Or you could do:
    squ = (~b2 >> 7) & 0x01;
    crs = (~b2 >> 6) & 0x01;
    cir = (~b2 >> 5) & 0x01;
    tri = (~b2 >> 4) & 0x01;
    R1  = (~b2 >> 3) & 0x01;
    L1  = (~b2 >> 2) & 0x01;
    R2  = (~b2 >> 1) & 0x01;
    L2  = (~b2 >> 0) & 0x01;
    lft = (~b2 >> 7) & 0x01;
    dwn = (~b2 >> 6) & 0x01;
    rght= (~b2 >> 5) & 0x01;
    up  = (~b2 >> 4) & 0x01;
    str = (~b2 >> 3) & 0x01;
    sr  = (~b2 >> 2) & 0x01;
    sl  = (~b2 >> 1) & 0x01;
    sel = (~b2 >> 0) & 0x01;
There are many other ways to do it as well.
chanyh
Post by chanyh »
Hi, Matt,
What are the meanings of the statements "B2=b2*(-1)+255;" and "B1=b1*(-1)+255;" and their purposes?
What are the values of the buttons in the PSP controller?
Can you help explain?
YH Chan
Before I learned about bitwise operators, I would use the statement B2=b2*(-1)+255; to invert a byte (bitwise NOT, in C represented by "~"). It is just a simple math function that would do just exactly what it looks like. It would assign the value of ~b2 to B2. "B2 equals b2 times negative one plus two hundred and fifty five".
The button values are as follows.
b1 series
sel =1
sl =2
sr =4
str =8
up =16
rght =32
dwn =64
lft =128
b2 series
L2 =1
R2 =2
L1 =4
R1 =8
tri =16
cir =32
crs =64
squ =128
Is that what you wanted?
You may also want to take a look at the Documentation with so many registers you'll start hearing "ka-ching" all the time. And don't forget the example program with its own library.
nxtboyiii
Post by nxtboyiii »
I agree with muntoo. The library is much easier to use.
BTW, when a button is pressed on the PSP-nx, the value equals zero, or false. So instead of doing, for example,
if(psp.square == true), it would be if(psp.square == false). :D
nxtboyiii wrote:...BTW, when a button is pressed on the PSP-nx, the value equals zero, or false. So instead of doing, for example,
That is why I use the bitwise NOT operator before I begin.
chanyh
Post by chanyh »
Matt, muntoo,
Thanks!
YH Chan.
Users browsing this forum: Semrush [Bot] and 15 guests
