Hi everybody,
I was wondering, if it would be possible to enable a robot to drive a straight line using Hitechnic's gyro sensor. I am not quite sure, whether the sensor could detect slight changes of the robot's steering. Would it be possible to sample the sensor at a specific rate per second (say 50 times) and then calculate the steering of the robot from that value?
Best wishes,
Alex
Going straight with gyro sensor
Re: Going straight with gyro sensor
Yes, it can do this. But you have to understand your sensor to do it right. There is a lenghty discussion on this forum about noisy gyro's that will help. On my blog there is some more usefull info about the gyro.
