Strange fseek behaviour in NXC
markcrosbie
Post by markcrosbie »
Hi John,
I've been experimenting with the fseek and ftell functions. Now according to the NXC documentation guide ftell will always return -1. However when I test the fseek() function after creating a file to move the file cursor to the end of the file I get an error 0x9300 - LDR_ILLEGALHANDLE. Does the current NXC release support moving the file cursor on a file that is open for writing? For example can I open a file for append and then move the file cursor back to the start of the file to write at the beginning of the file?
Here is my sample code:
// File position testing
// Use the rewind, fseek, ftell functions to position the
// file read cursor
#define FILENAME "seeker.txt"
#define FILESIZE 100
task main() {
	unsigned int r;
	int f;
	int cursor;
	DeleteFile(FILENAME);
	r = CreateFile(FILENAME, FILESIZE, f);
	// where is the file point at?
	cursor = ftell(f);
	TextOut(0, LCD_LINE1, FormatNum("ftell=%d", cursor));
	// move to the end of the file
	r = fseek(f, 0, SEEK_END);
	if(r != LDR_SUCCESS) {
		TextOut(0, LCD_LINE2, "fseek failed");
		TextOut(0, LCD_LINE3, FormatNum("Err= 0x%x", r));
		Wait(5000);
		StopAllTasks();
	cursor = ftell(f);
	Wait(5000);
Any ideas?
Thanks,
Mark
