I wrote an article on the subject at http://broija.blogspot.com/.
For the moment, it explains only how to do so on Linux but I'll add a tutorial for Windows soon.
B.
Compiling and running Qt 5 for the EV3
Re: Compiling and running Qt 5 for the EV3
Could you comment about the potential uses for this software?
Lauro
http://www.robotnav.com
STL is powerful but is often not sufficient. Qt is a great C++ API which propose plenty of tools (network, multithread, XML, ...).
The signal/slot mechanism is quite intersting. It allows you to do the same thing as function pointers and functors (except that you can't return anything from a signal) in an easy and pretty way.
The thread classes and methods are quite easy to use too.
The main reason that led me to compile it for the EV3 was to use a TCP/IP server class without reinventing the wheel. I wanted to command the EV3 remotely with an Android device. Of course, I could have used netcat to listen and redirect its output to my program but that seemed quite twisted.
I would say that if you want to code something and you know that it has probably been done before, then Qt is probably doing it already.
My blog: http://broija.blogspot.com/
It would be great if you could make it work with the standard framebuffer device (/dev/fb0) on the EV3 brick.
= Xander
= Xander
Hi Xander,
Thanks for answering. I'll give it a try.
This is done. Xander, thank you for your suggestion. Another topic has been created with the links: https://sourceforge.net/apps/phpbb/mind ... f=3&t=2023 .
B.
B.
I look forward to seeing your ports of KDE and GNOME
= Xander
= Xander
