PosRegEnable -does'nt work
Re: PosRegEnable -does'nt work
SetOutput(PORT, PowerField, 0,
                        OutputModeField, OUT_MODE_MOTORON|OUT_MODE_BRAKE|OUT_MODE_REGULATED,
                        TachoLimitField, 0,
                        UpdateFlagsField, UF_UPDATE_TACHO_LIMIT|UF_UPDATE_MODE|UF_UPDATE_SPEED);
Hell, what a function call to brake a motor! Or does it more than just brake? I don't see through that elaboration.
Anyway, I think I'll propose it for the Nobel Prize for Literature :D
felix2ch
Post by felix2ch »
doc-helmut wrote: Hell, what a function call to brake a motor! Or does it more than just brake? I don't see through that elaboration.
That 's why john said " though that could easily be wrapped in a preprocessor macro API function. ".
surely it can be done.
Related to the original source code, I'm simply confused about the original number of letters, the (actually, apparently) non-C-like syntax structure, it's complexity and sophistication and the amount of OR-ed expressions or variables which are cited.
(That's one of the reasons why I in principle use my own PID controller, hereby I know what it does and how it works - but that's admittedly my own personal problem and should not (and must not ) bother you in any way.)
felix2ch
Post by felix2ch »
doc-helmut wrote:surely it can be done.
Yes, it should be more clearly and more flexible if use own PID controller.Of course, all regulation options in firmware will be give up.
