[resolved] forum posts blocked with initial "@"
Any feedback to improve the content of this site is appreciated!
if I write a post, I can open the editor window but whem I press "submit" the forum often hangs up.
e.g, I cant post a reply to the "US strange behavior thread":
@John:
Anyway, IMO it's not good that you always have to wait for each US call, because if I want to poll many sensors in 1 polling loop a must-wait(15) for each USS reduces needlessly the polling frequence of all other sensors, i.g. touch or light in the same loop.
It must be able to switch off this built-in wait(15) if one wants.
(In C the programmer is responsible for everything what he's doing...)
What's on?
Re: forum posts blocked
(edit, update):
this is an issue of 2 different PCs at different locations via different internet providers
It is also not possible to post into other software subforum threads
Re: [resolved] forum posts blocked with initial "@"
That was mentioned quite a while ago. The easiest way around it is to use a different character instead, or precede it with a space (which will automatically be removed).
yes, after it worked once and not again, I remembered it quite dark, so I've finally come to the cause of this issue.
BTW, this is not a php forum issue, in our German forum this is easily possible...
Users browsing this forum: Amazon [Bot] and 13 guests
