wishlist for BricxCC
Re: wishlist for BricxCC
well, most of all cases I'm just replying if I have been approached before directly. :roll:
But the failure of one member does not implicate that anyone else may have the right do the same mistake(s) repetedly. ;)
Anyway, I will reflect and will promise to do my very best and to behave better in future :)
@admins:
please delete all trash and chunk :mrgreen:
BTW:
to make sure that real wishes will not get dropped between discussion, the following was my wish in memory:
doc-helmut wrote:John,
why isn't it posible to make *.h files work with BCC just like *.nxc files (for text highlighting and debugging)?
@admins:
How about you just don't create any so we don't have to clean it up.
Of course I didn't mean myself, I certainly meant the others.
nxtboyiii
Post by nxtboyiii »
Could you make it so NXTScreen uses display flags, like if I do SetDisplayFlags(DISPLAY_REFRESH_DISABLED) then NXTScreen will disable the refreshing?
nxtboyiii
Post by nxtboyiii »
So can that not be done? All that has to happen is that in NXTScreen it responds to the display flags on the NXT.
I just really want that.
I wish there was an option at download time, to download the current program as "! Startup.rxe", and delete any previous file with the same name (should be done automatically).
jld001
Post by jld001 »
A really cool feature for BCC would be
DebugOut("write stuffs here");
The function would basically, display "write stuffs here" in a debug window.
Something like that would help me so much for debugging. Sometimes TextOut doesn't work because the program aborts, etc., and PlayTone doesn't work well for debugging because it can be hard to distinguish between different tones when you need lots of debugging messages.
Would any one else be interested in this feature?
Does anyone know of a way to do something like this?
My Githubz of Source Codez, in order of awesomeness:
https://github.com/ArtskydJ/NXC_Source
https://github.com/ArtskydJ/NXC_Tests
My Lego Creations, in no particular order:
LEGO Bop-It - http://www.youtube.com/watch?v=6TsqrBVKbj0
LEGO Safe - http://www.youtube.com/watch?v=MyDRfVquHuY
That was just added! It's called "Simple Terminal", and it prints whatever you send to a mailbox (selectable).
jld001
Post by jld001 »
Oh, OK. Sweet!
One more thing. In the following posts, I see a tabbed window mode, and I can't find that anywhere in the newest test build. I looked all over the preferences. Thanks!
http://sourceforge.net/apps/phpbb/mindb ... 140#p12893
http://sourceforge.net/apps/phpbb/mindb ... 140#p12914
To use tabs, go to Preferences > General (default page), and unselect "Use MDI Mode"
Users browsing this forum: Semrush [Bot] and 33 guests
