Need help: Solved
dudmaster
Need help: Solved
Post by dudmaster »
Well i am trying to make a text input using 3 keys. L/R to select letter, enter to choose.
My code gives me a file error. Code 5.
task main() {
string Alphabet[] = {"a", "b", "c", "d", "e", "f", "g", "h", "i", "j", "k", "l", "m", "n", "o", "p", "q", "r", "s", "t", "u",
"v", "w", "x", "y", "z"};
string L1, L2, L3, L4, L5, L6, l7, L8, Sen, Sen2;   // Hax Ngn: Direct NeX Edit  :o (hide the answer!!!!!)
bool S;
int N;
while (S == false){
while (0 == ButtonCount(BTNCENTER,true)){
if (ButtonCount(BTNLEFT,true))
  N--;
if (ButtonCount(BTNRIGHT,true))
  N++;
Sen2 = Alphabet[N];
TextOut(0, LCD_LINE3, Sen, true);
TextOut(0, LCD_LINE5, Sen2);
StrCat(Sen, Sen2, Sen);
Not telling what it's for... Hey! cover it up!
2Labz.com, My Website
dudmaster
Re: Need help: Solved
Post by dudmaster »
I solved it using this code:
task main() {
string Sen = "", Sen2 = "";   // Hax Ngn: Direct NeX Edit
bool S = false;
int N = 0;
while (S == false){
if (ButtonCount(BTNLEFT,true) && N > 0)
  N--;
if (ButtonCount(BTNRIGHT,true) && N < 26)
  N++;
Sen2 = Alphabet[N];
Wait(20);
Sen = Sen + Sen2;
THIS is why you should almost always initialize variables as soon as you declare them. Especially pointers (to NULL).
Whenever you need an alphabet letter, instead of using string Alphabet[] why don't you do this:
string szLetter(int idx)
    idx += 'a';
    return(FlattenVar(idx));
Now, replace "Alphabet[N]" with "szLetter(N)"
Also, string L1, L2, L3... could be turned into
string L[];
ArrayInit(L, "", 8);
Also, you can improve your code like this:
    idx += 'a';
task main() {
string L[];
string Sen, Sen2;   // Hax Ngn: Direct NeX Edit  :o (hide the answer!!!!!)
int N;
while(1)
if(/*S==0*/)
    break;
while(!(ButtonPressed(BTNCENTER, 0)))
    if(ButtonPressed(BTNLEFT, 0))
        N--;
    if(ButtonPressed(BTNRIGHT, 0))
        N++;
    Sen2 = szLetter(N);
dudmaster
Post by dudmaster »
Thanks, muntoo- but a little late.
Text Edit program including file read here now!
