adjust the size of the Bricxcc templates pop up window ?
is it possible to adjust the size of the Bricxcc templates pop up window (right mouse double click)?
the pop up window is bigger than my screen and I can't see the last bottom line(s)!
Re: adjust the size of the Bricxcc templates pop up window ?
Increase the computer display resolution, and then shorten the templates list. You could then resize the display resolution to the correct size, and that should do it for you. Once it is how you want it, it should be proper every time you open BCC afterwards. If my first suggestion doesn't work, then you could make dummy template folders at the end of the list to push the real ones up, so to speak.
not possible!Increase the computer display resolution,
as I wrote, I want to adjust the pop up window size (or have a scroll bar), not the display resolution!
I know, but I meant to change it temporarily, so you could drag the bottom up, then decrease the resolution back to the original size. It should give you the scroll bar automatically, I think.
Edit: It automatically gives me a scroll bar.
how can I change it "temporarily" ?
Well, you change it normally, then change it back later. for a Windows OS, you should be able to go to the desktop, right click, and (based on the specific OS), you either click on "Screen Resolution", or you click on "Properties" > "Settings", and adjust it to a larger resolution. Do the same to change it back.
no, as I wrote: I can't in increase the screen resolution.
I currently use 1680x1050
If you can get it to give you a scroll bar, then just make a couple dummy folders.
how can I make dummy folders?
Open BCC, and go to Preferences>Templates>NXC. Scroll down to the very bottom and make more folders. An example would be something like:
MSScoutSetSensorLowerLimit("src", "value");\=
MSScoutSetSensorUpperLimit("src", "value");\=
MSScoutSetEventFeedback("src", "value");\=
MSScoutSendVLL("src", "value");\=
MSScoutSetScoutRules("m", "t", "l", "tm", "fx");\=
MSScoutSetScoutMode("mode");\=
-dummy
-dummy
-dummy
-dummy
-dummy
A new folder is represented by "-name" (where name is the name of the new folder). In thins case, I did "-dummy".
-dummy
-dummy
-dummy
-dummy
-dummy
